Another Cold Air Intake Question
ya its mostly to set the idle rpms, which really doesn't come into play unless you get a new throttle body or something. Your car has already learned from whatever you added 3 tanks ago.
Back From The Banned!
Originally Posted by JesterMasque
Well I'm about 3 tanks out so... I'm good then, right?
Originally Posted by CuRiOuSfIsH
youre fine, but there was a member on here that installed an intake and didnt reset.... went out for a test run, came back, the header was glowing red....
Thanks guys. I just now read replies on that but I didnt unhook the negative battery terminal. By the way, cold air intake is installed! Check out the DIY on AEM cold air intake and it tells you how to reset your e.c.u.
I did however have a problem when taking off the factory air intake enclosure(where the air filter is at)! 3 of the 6 bolts stripped out ,breaking the plastic casing the bolts thread into. But my friend who has owned and worked on some of the nicest automobiles (Supra, Peugot etc.) spotted a clamp around the throttle body, under the casing with the filter in it. He loosened the clamp and off came the box! I will have pics of the clamp and the stripped out bolts soon........and here are the pics
Originally Posted by gearbox
thats a common problem with the lx anyway. header gets clogged up too easily and then overheats.
ORskier
May 7, 2015 04:54 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
SneakerPimp
Nov 4, 2001 01:12 PM
