Need Help (Oil Pan)
Old Jan 5, 2004
ninerfan17's Avatar
ninerfan17 is an unknown quantity at this point
Need Help (Oil Pan)
i screwed up today when i accidently cross threaded my drain plug, so i need a new oil pan. Besides the oil pan and sealant, does anyone know if i need anything else in order to replace it. Plz respond if u know.
Old Jan 5, 2004
tuffy7's Avatar
tuffy7 is an unknown quantity at this point
Ninerfan:
Buy or borrow a metric tap. Bring your drain plug so you
can match the plug with the tap. Chase and clear your old
threads in the pan and install a new plug and gasket.
This works most of the time and is worth a try.
Good Luck............
Old Jan 5, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
^^^^ I agree... its worth a try. Just waste a quart of oil and pour it straight through without the plug to make sure you flush any metal junk the tap cut loose... otherwise it'll make its way through the oil system, which isn't good.
If you have to replace it though... change the gasket with it.
Old Jan 5, 2004
ninerfan17's Avatar
i talked to the guy at honda and he said that there is not a gasket on it but just a sealant.
SidCivic
17
Aug 23, 2015 03:14 AM
mrwhos
Aug 11, 2015 02:03 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
Q-Bert
Jul 19, 2015 09:09 PM
