Steering Wheel Removal Problem
Old Dec 23, 2003
CarloChan1's Avatar
CarloChan1 is an unknown quantity at this point
I'm having trouble taking off my steering wheel. I removed all the bolts and wires, all i have left is taking off the steering wheel itself. I yanked and yanked and even got the steering wheel puller from autozone, but no luck. Am I missing something? I have the DX is there a difference with the EX and DX steering wheel?
Old Dec 23, 2003
cheukkin's Avatar
cheukkin is an unknown quantity at this point
are you sure you did remove all the bolts? Don't forget to take the one big bolt off located in the center of the steering wheel, then use some power pull toward yourself then the SW will take off all the way.
Old Dec 23, 2003
CarloChan1's Avatar
Yep. I removed the 19mm bolt. I pulled and pulled, but nothing.
Old Dec 23, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
just keep pulling, the steering wheel puller should work, its very easy with the puller if u have stock steering wheel, but i had problem getting the momo steering off, but stock steering is easy
Old Dec 23, 2003
CarloChan1's Avatar
I must be missing something then. Do I need to doing anything with the ignition or keys? I know my wheels still move when I turn the SW. Is there a lock or something holding me back?
Old Dec 23, 2003
Pharoh's Avatar
Bobaganoosh!
^^ Nope, just pull. The puller should do the trick though.
I put the Si/SiR wheel on mine and that was all I had to do.
Note: If you haven't, you should disconnect the battery as well.
Old Dec 24, 2003
tfnaaf's Avatar
BLDNPSI Mod
Sometimes with tension on the puller tapping on the end of the puller with a hammer will break free the steering wheel
Tedverseti
Apr 23, 2020 01:45 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
nymbus2k
Nov 11, 2001 08:53 PM
