In need for someone with a 2001 civic Helms Manual
Old Jan 28, 2004
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Hey everyone, I have a 2001 civic ex coupe. I need someone to get me some information from the Helms Manauls. I need the following tourque specs and information. THanks everyone!
Valve cover tq specs
Crank Pully Bolt Specs
Water Pump Bolts
timing belt tensioner bolt
Also the specs for doing a valve adjustment.
Thanks everyone for your help!!!!!
Old Jan 28, 2004
acidbaby's Avatar
The Beez Kneez
ask civicvtec1ps
fukr knows everything
Old Jan 28, 2004
C2i0v0i1C's Avatar
SuperMODrizd
valve cover 7.2lbf.ft
water pump 8.7lbf.ft
Old Jan 28, 2004
civicvtec1ps's Avatar
Search and Learn
Originally posted by acidbaby
ask civicvtec1ps
Don't have helm guide for 7thgen coupes and sedans.
I have helm guide for ep3.
"Jeff" has helm guide. PM him.
Old Jan 28, 2004
Civicious's Avatar
Civicious is an unknown quantity at this point
I've got the manufacturer repair manual. I'll check when I get home if someone doesn't beat me to it.
Old Jan 28, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i have one thats where those numbers came from
Old Jan 28, 2004
civic01vtec's Avatar
Old Jan 28, 2004
syndrome's Avatar
syndrome is an unknown quantity at this point
hahaha
Old Jan 28, 2004
djmota's Avatar
33 ft lbs final tightness on the tensioner bolt.
crank pulley bolt is, first 14 ft lbs then tighten the bolt an additional 90 degree turn.
got to love the green bible
Old Jan 28, 2004
C2i0v0i1C's Avatar
SuperMODrizd
hey what page was that on
Old Jan 28, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
you really should buy your own manual...im not flaming you, but its REALLY nice for doing anything on your car...btw, did you get all the numbers you needed?
Old Jan 28, 2004
Civicious's Avatar
whoops didn't see your post. Looks like I didn't get home in time anyway, someone already beat me to the other numbers. I agree it's best to buy a manual if your serious about working on your car.
Old Jan 29, 2004
bhaz413's Avatar
yeah I should but I already know how to work on cars. Just needed the specs
But thanks everyone for the help!!!
BTW I will be doing this on sat, full DIY and pictures. Stay tuned!
Old Jan 29, 2004
djmota's Avatar
6-22 THRU 6-24
timing belt replacement
Old Jan 30, 2004
reytito's Avatar
whered you guys pick up the book?
Old Jan 31, 2004
jwalker87's Avatar
Bodacious Member
www.helminc.com (i think)
Old Jan 31, 2004
reytito's Avatar
got it:
linkified
Old Feb 1, 2004
bhaz413's Avatar
Re: In need for someone with a 2001 civic Helms Manual
WELL IM DONE FINALLY!
After working a 9 hour shift, I started the project with my friend. Took us a total of 13 hours to finish it. Lets just say this is a project that is not for the un-technical.
Here it is in a run down if you have a 01 ex w/ abs. Yeah I said I was going to take pics, and a DIY. But it got to that points of I was too tried, and up for 27 hours lol.
Take all the junk off the valve cover (spark plugs, mounting brackets ect...)
Unbolt the valve cover adn remove it
Unbolt the timing cam cover and remove it
Unbolt the power stearing belt, and push it up out of the ways
(dont remove the lines or you will have to bleed it
Unbolt and remove the alternator
Unbolt the water pump and tensinor cover
Set the timing cam and the crank pully to TDC, and mark it
Loosing the crank bolt
Set TDC again to make sure it didnt move
Remove crank bolt (with special tool)
Take crank pully out, make sure not to drop this special key that inserts into it. Its wicked small, and it is hard to loose.
Slip off timing belt
Take out tensionor and replace it with a new one. You have too because it is a automatic one, and once you take it off you have no choice but to replace it.
Drain radiator, and milk the lines clean with no fluid
Remove water pump (i suggest replace it too)
Clean spilled fluid off the pullys and engine, it can eat the new belts.
Install new timing belt, tensinor, water pump and belts in reverse order. Go get a beer cause you are exhausted
Done
Old Feb 1, 2004
bhaz413's Avatar
Re: Re: In need for someone with a 2001 civic Helms Manual
Oh yeah, this was just with TQ specs from everyone. No helms needed
Done
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
