putting fiberglass over your dash
Old Jan 22, 2004
Ohsosikcivic's Avatar
Ohsosikcivic is an unknown quantity at this point
anyone know... if you can use Bondo or WHAT material u can use to make the dash smooth looking like you'd see in sport compact or anything like that???
Old Jan 22, 2004
ImPulse's Avatar
cf overlay.... ?
or full custom thingy... I never heard of a material to make the dash smooth like fiberglass =\
Old Jan 22, 2004
Fletchman04's Avatar
Fletchman04 is on a distinguished road
ya you're talking about an overlay of either cf or fiberglass. there are full dash replacements, but it can be expensive....
Old Jan 22, 2004
TunedNCivic's Avatar
TunedNCivic is an unknown quantity at this point
if youre planning on painting the dash and other interior plastic pieces, there is an article in the new Import Racer magazine that explains the steps. No fiberglass is needed. Its a very good article
Old Jan 22, 2004
i just thought some people laid fiberglass over it and let it set... sanded it down and painted it for a smooth finish, kinda like how they do speaker boxes??
Old Jan 23, 2004
CPEasy02's Avatar
CPEasy02 is an unknown quantity at this point
you can but i personally wouldn't do it....i would just stick with painting the trim pieces imo
Old Jan 23, 2004
solar's Avatar
solar is an unknown quantity at this point
Don't cover up the passenger air bag, that could cause a problem.
Old Jan 23, 2004
blucivic's Avatar
blucivic is an unknown quantity at this point
you got to sand all the texture down till its smooth....then use a high build primer, sand, primer...till you get the smoothest possible feel. then just paint, and clear coat(not spray paint, use a professional paint gun if you want it to be shiny like your car after a fresh wax), color sand then buff.
for the padded vinyl part...you will either have to fiberglass, or get a whole new plastic mold.( you should have a profesional do the work for you, cause it is a lot of hard work and time involved) good luck!!!
Old Jan 23, 2004
Seabass's Avatar
Seabass is an unknown quantity at this point
If you wanted to do the fiberglass part this would be the basic steps. First figure out where your gonna fiberglass, then make a frame outa fiberglass, then cover the spots that might get fiberglass resin on them. Then use cloth to wrap it around your frame and to where you want it to go(use a glue gun to help you keep it in that spot) then put fiberglass resin/hardener and soak i into the cloath, then after its dry begin to fiberglass on it. Then after your done about 5-7 layers(matters how strong you want it) then use bondo to make everything smooth, then sand it, bondo again...until you get it perfect. Then take it to a shop and get it painted
Old Jan 23, 2004
Explosivo's Avatar
The dog told me to do it
Explosivo is an unknown quantity at this point
no offense... but from my experience of working with fiberglass on my sailboat is that what you (ohsosik) described would best be left to professionals, particularly if you've never worked with glass. The 'correct' way to do it would be to make a female mold of your actual dash piece (removed from the car) and then make a fiberglass piece from the mold. I would NEVER recommmend overlaying the dash WHILE it's in your car, particularly if you've never done it before. Resin is messy and a beatch to clean.. and the car is too tight a space to work in.
Old Jan 23, 2004
Seabass's Avatar
Sorry, when i wrote
I meant make a frame outa wood, and i was describing more towards something like putting in a custom screen. Its ok as long as you cover all areas, and if you get it on the carper it WONT come out. Sorry if i made it sound like it was for the entire dash...
Old Jan 23, 2004
Yes, that would be the best way, but its impossible. The backside of the dash is injection molded. There will be no way to make a mold and reproduce the dash in fiberglass and keep the clips and holes on the backside to install. Well, i take that back, not impossible. But VERY EXPENSIVE.
Old Jan 23, 2004
Dont forget that the primer and paint must have a "FLEX" additive. Plastic expands and contracts due to the temperature, and the paint must be able to flex with the paint or it will crack.
KronikScott
Jun 9, 2015 08:00 PM
SSMatey
Apr 13, 2015 06:09 PM
djdefcon
17
Apr 6, 2005 11:52 PM
