the technical side or RSX seats and SRS??
Old Jan 27, 2004
rowdyb7's Avatar
rowdyb7 is an unknown quantity at this point
Ive researched this but didnt find very solid answers.
OK I have a 2001 Honda Civic coupe lx with the factory optional side airbags in the stock seats. I need to find out if the RSX seats with similar side airbags with be 100% compatible. I need to know if the seats will swap in and the airbag connectors will connect perfectly, and if you can then reset the SRS light and have the light stay off. I need to know if after these seats are installed the RSX side airbags and my stock front airbags will all work perfectly still and in the event of a wreck. I have had some rough experiances with seat swaps in my car and I need to concrete descriptive responses.
I talked to the dealership who said that he would need to compare the seat diagrams and all the wiring and sensors to see if they would be compatible and not just look compatible. Thanks in advance for your help.
Brandon Millard
Admin
ImportsNC.com
Old Jan 27, 2004
XTREME2K2CIVIC's Avatar
Reppin Stage 7
I recently installed the RSX Seats in my car but have yet to go to honda to have them reset the SRS that had turned on with my other pair of racing seats...The harnesses all plugged directly in with no problem.. On thing that I did notice was that the safety feature that disarms the side airbags say when someone is leaning on them and deactivates the side airbags works .. I am assuming if I take it in that should eliminate the srs light completely..
Old Jan 27, 2004
bigtime's Avatar
bigtime is an unknown quantity at this point
I installed 2002 SIR seats in my civic coupe and everything was fine. The plugs fit perfectly and I was able to reset the srs light myself.
I think the RSX should be the same.
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
cukaracha
May 16, 2015 02:11 PM
SimDogg
Nov 27, 2001 04:20 PM
artychris
Nov 11, 2001 10:23 PM
