Grounding the alternator??
I know a number of people have installed a grounding kit in their engine bay (either homemade or aftermarket), and I was wondering if anyone can tell me exactly how they added a ground wire to their alternator. Where on the alterntor did you attach the ground? Any info on installation, pitfalls, etc. would be greatly appreciated.
I've seen a number of pics here on grounding kits, but I have yet to see a pic of where a ground cable attaches to the alternator.
Thanks again!!
Thanks again!!
The alternator actually doesn't get grounded with a cable / wire, it is grounded via the engine frame. There are only two things that get attached to it - a voltage monitor wiring harness, and the positive cable which goes to the battery. What people really change is just the positive power cable which goes to the battery. After I did mine (all main power / grounding feeds), the first thing I noticed is the windows and wipers work better....
Actually, there is a small 5mm hole on the back of the alternator. I made a ground wire from the back of the alternator to the battery. That way the alternator is grounded and will charge the battery as efficently as possible.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
msaeger
Sep 2, 2015 08:47 AM
