Engine Swapping
Old Jan 14, 2004
Rionmann3's Avatar
Rionmann3 is an unknown quantity at this point
Engine Swapping
Well i am a beginner when comes to do any engine swapping. Wo, i wanted to know if it is neccassary to get a new transmission and ECU when getting a new engine?
Old Jan 14, 2004
01civicUP's Avatar
01civicUP is an unknown quantity at this point
yes if ur going to swap it out with a SI or RSX engine your going to need a new trany. and im assuming the same for the Si too. but not totally sure. And yes you will defantly need a different ECU. But these things should come with the egine when you buy it. so make sure okay.
Old Jan 14, 2004
whitebread's Avatar
whitebread is an unknown quantity at this point
anyone know a good place to get a K20 motor new or used?
Old Jan 14, 2004
Jaykuai's Avatar
ish...
car-part.com
forsale trade forum.
(3 K20a3's for sale and a totalled rsx-s)
Old Jan 14, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
you will also need a new radiator, different hoses, custom shift linkage, hasport motor mounts
RSX Type s subframe and honda to flash your keys/immobilizer/ecu to work.
Old Jan 14, 2004
Texas Rice's Avatar
Texas Rice is an unknown quantity at this point
And you need too much money.
Old Jan 14, 2004
WhiteCastle's Avatar
you will also need a new radiator, different hoses, hasport motor mounts
RSX Type s subframe and honda to flash your keys/immobilizer/ecu to work which is easy.
like to add new tack and while your at it new springs are needed. custom shift linkage is not needed however. Also you like to take in consideration this is a extremely difficult swap, its not as easy as lets say installing a greddy turbo. Well for you guys installing a Standford fabrications turbo. Which I soon might order when Catalyst gets the dang thing CARB cerified in california or he can garuntee it will pass smog for me if I got an aftermarket cat ex downpipe etc...
Now for the project car we have a K20a2 not mounted yet.it is installed with a greddy turbo running 7 psi at 285 Bhp. This involved significant tunning and parts from AEM, yes the engine was built to be reliable as it can be. I wanted to tell you this because it proves the potential of such an engine over the D17.
Old Jan 15, 2004
Rionmann3's Avatar
Could you guys give an estimate of how much that would cost, i goin to get a h22 or a k20(preferrably). so, if anyone could help please post for me...
Old Jan 15, 2004
k20 will run you between 8 to 10 grand if you dont do it yourself and an H22 i really dont know about. I could go on listening the parts for you but figure giving you it straight up view of the cost.
Chearper to get a standford fabrications turbo, Im waiting for catylist to get it carb so I can do that on my own car. Our friends race engine , we havent descided which car its going in yet rofl is a k20a2 with a greddy turbo
Old Jan 15, 2004
Jodster's Avatar
Post Whore General
The swap is not that hard if you know much about Hondas.
You will need a few things custom made.
K20 drop out(Motor, tranny, ECU, subframe, ect.)
02 and up SI axels(to be able to keep 4 lug)
02 and up SI radiator and hoses
Hasport mount kit
Custom Clutch lines
RSX shifter cables
RSX PS resivor and line(if PS is wanted)
custom AC lines(if AC is wanted)
Hasport wiring harness(or custom your own)
ECU reflashed with your key code
And there might be a few things I forgot. OVer all the swap is not that hard. There is a lot of info on this. Search about it. Nobottlejusttrottle and Hawk are ones that did the swap and talk about it during the process. Look there old threads about their swaps and you find tons of info on it.
I myself will be doing the swap over this summer. I have already started buying parts that are needed and will hopefully finish everything by Fall. If no one has done a DYI on it by the time I start installing mine, I'll write one up. If you are going to do the swap and decide to do it yourself and are going to buy parts one at a time(like I am) buy the motor last. K20s are getting cheaper now and in the next few months you should be able to get good deals on them.
Old Jan 15, 2004
let me know where you stick the air conditioning? i havent figured that out yet rofl
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
