oil pressure dropping part 2
okay i know you all read about my oil pressure and everyone said it shoudl be around 80-90 psi at fukk throtal but its only at like 65-70 now what shoudl i do what coudl be the problem i knwo it has something to do with the VTEC becasue of the p1259 code so does anyone know where there problem might lay someone pelase help becuase i don't want to drive my car and **** it up thanks please please please help me
i just changed it not that long ago i think there is a pressure leak but i dont' know becasue it will go form like 110 psi then when VETC starts to kick it drops to liek 80 then when it gets a little warmer it drops to 70psi then it won't go up and i just changed the oil like 1000 miles if that and im running a 5w30 so someone has to knwo what the hell is goign on please help
take it to the dealer. They will have to run a bunch of tests with special tools that you probably don't have to figure it out. The vtec code may be because of the low oil pressure, or it or a component of it may be the cause of it.
before you take it in change the oil and filter to the proper wieght 5w-20 so they don't blame you.
the honda dealer around here wants 69.95 an hour just to look at it and i had it there once already when it first started and they said nothign was wrong so i dont' knwo what to do i dont' have that kinda money to dish out do you or anyone know where it might be comming from ??????????????? or have any idea at least
I wish I was asian
i'm guessing you're getting these readings from an oil pressure gauge you mounted in your car...
if so, what brand is your gauge? it might not be accurate at all.
Xuhme
21
Aug 7, 2023 03:40 PM
Supramk3
May 11, 2015 07:55 PM
crowtoo
May 11, 2015 06:50 PM
Chronic_issues
May 8, 2015 05:40 PM
