Rear Spring/Strut Install Question
Well I just took off my Rear Tein and when Im putting the OEM unit back on, the suspension hangs lower than where it needs to bolt on. Both sides of the car are jacked up. How can I get the suspension to line up with the bottom bolt (the one u need to push on one side of).
Thanks
Thanks
Do you need to use a spring compressor when putting them back on? I got the top nut on but I didnt crank it down all the way before I tried putting the struts back on.
Like he said above a big pry bar, if you wheel is on a easy way is to use a large board under the tire as a lever. I dont recall it being to difficult to get it lined up. This is asssuming that you are saying the suspension is hanging lower than the strut. if its the other way around just push down on the tire to lower the suspension down to the strut.
edspyhill09
Jun 12, 2016 02:45 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
edgenet
Apr 28, 2015 07:49 PM
ej8
Apr 13, 2015 06:36 PM
