short shifter problem?
Old Dec 29, 2003
JDMsicvic's Avatar
JDMsicvic is an unknown quantity at this point
Hey i installed my DC sports short shifter three months ago..and guess wat my third gear is like grinding hardcore......ok now......we just installed my friends short shifter on his 03 tiburon..and now its doing the same thing.....? do all short shifters do this? i mean i dont think they should? but i dunno....please help?
Old Dec 29, 2003
Vinh's Avatar
shoulda gotten the full Revo Assembly
Old Dec 29, 2003
CapYoda's Avatar
Escaped Convict
open it up and check if its loose, if it is there may be troubles getting into the gears you want.
sometimes those adapters, or at least DC version of them gets loose cuz the hex key nut comes lose from engine and driving vibration.
Old Dec 29, 2003
k20a1emcivic's Avatar
-=* I LOVE MEN*=-
k20a1emcivic is an unknown quantity at this point
hey guys im thinking about getting the revo short shifter adaptor kit myself and i was wondering if theres any difference u can feel, as in shorter shifts cuz some short shifters dont help for crap. they just sell u a stick. lol but is there a noticable improvement?
Old Dec 29, 2003
civic01vtec's Avatar
i haven't installed mine yet (sits in my room in the box) but everyone that has it loves it and says they can feel the difference.
Old Dec 29, 2003
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
how in the hell can a short shifter help??
Old Dec 29, 2003
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
The revo SS is the way to go, along with capyoda's bushinings. The SS does a few things - shorter throw, which means less time and effort to get thru the gears, it is a lot less sloppy than the stock assembly. It is a great upgrade, add a momo shift **** like I did and it looks sweet as hell. Go with the full kit, not those cheap adapters.
Old Dec 29, 2003
2003hondacivic's Avatar
2003hondacivic should not be trusted2003hondacivic should not be trusted2003hondacivic should not be trusted
i installed a dc sports short throw and i love it
i have no trubles from it
Old Dec 30, 2003
Master's Avatar
Banned by Admin
Less time out of gears, the less time you are out of gears, the more time you are using your engine. That how it helps, no one even needs to make a long response, this is all you have to say.
Old Dec 30, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Capyoad's bushings plus Grey's upgrade kit really help the shifting. And if you put on a nice heavy shift ****, it helps quite a bit.
Old Dec 30, 2003
l00pb4k's Avatar
But it's a Dry Heat
l00pb4k is an unknown quantity at this point
Have the Revo full kit. It is definately worth the money and you don't have to worry about an adapter getting loose.
Old Dec 30, 2003
quick83's Avatar
quick83 is an unknown quantity at this point
since your on the topic of the revo, i have one with capyoda's bushings and greys upgrade kit, and my shifter is pretty sloppy, more then stock. I located the problem to the ball joint on the shifter, are they all like that? Should i buy a new revo, besides that problem i love it and would never go back to stock
Old Dec 30, 2003
skipbarber's Avatar
i dont even remember what stock felt like....i like my revo SS.
Old Dec 30, 2003
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I just installed the generation 2 adjustable short shifter for the Type S in my civic coupe and it works great. I used to have a "clipping" problem when shifting into third gear when the transmission was cold but installing the REVO seems to have helped that.
Quick 83, did you grease the hell out of that joint? Maybe your assembly is defective?
Old Dec 30, 2003
l00pb4k's Avatar
But it's a Dry Heat
Dunno, I just used the Revo kit as it came. Didn't upgrade bushings or anything, it's working just fine.
Old Dec 30, 2003
Drkstalkerr's Avatar
Drkstalkerr is an unknown quantity at this point
man i installed one of those cheep kits, haven't had any problems with it. i am just waiting to get the money for the revo baby.
Old Dec 30, 2003
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
True dat. Easy to install and a vast improvement over stock. Just make sure u buy new cotter pins cus the stock ones are pretty weak after the install.
Old Dec 30, 2003
ehh, they have done just fine, and i have had it on there for about 6 months now
Old Dec 30, 2003
VtecEx's Avatar
VtecEx is an unknown quantity at this point
If your using the adapter put some lock-tite on the threads and it will be fine
Old Dec 30, 2003
SMX's Avatar
SMX
SMX is on a distinguished road
The adapter was a step in the right direction on my car. The Revo SS took it to the next level. Big difference. My wife can even shift it without grinding with the SS.
Old Dec 30, 2003
JCiv03's Avatar
pretty sloppy? do you mean side to side play? like it movees from side to side when its in gear? if so, someone on this site found the solution to that problem.
if it is, then just refer to this
http://www.7thgencivic.com/forums/sh...revo+side+play
Old Dec 30, 2003
tavdawg's Avatar
tavdawg is an unknown quantity at this point
Where are a couple places that you bought your revo ss from and also the Capyoda's bushings and Grey's upgrade kit you are talking about?
Old Dec 30, 2003
sauercivic's Avatar
sauercivic is an unknown quantity at this point
has anyone tried the Venom Tech short throw kit, it looks sweet you get the entire kit with a new boot and ring, wonderring if anyone has tried
Old Dec 30, 2003
Decamo's Avatar
Decamo has a little shameless behaviour in the past
Are you kidding me? The only reason you would get a short shifter is for feel and personal preference. Saying that it will increase your shifting speed is ridiculous.
I've had both a DC sports adapter and the revo in the past. A short shifter will make your shifter more harsh and you will not notice the shortened throw after you get used to it. So the only thing you are left with is a harsher shift.
Had the revo on for about 6 months and loved it at first. Then i got used to it and didn't notice the shortened throws so i took it off and whoah! Stock is smooth as butter compared to short shifter!
So again its just personal preference on feel. And I now run stock.
Old Dec 30, 2003
pxboarder's Avatar
pxboarder is an unknown quantity at this point
im not even going to flame you about what you just said all im gonna say is... wow
Old Dec 30, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
revo gets thumbsup from me i like it
Old Dec 30, 2003
modoman's Avatar
i got a neuspeed adapter on now for about a month... works fine and i noticed a difference... shifts better than stock anyday if you ask me
Old Dec 30, 2003
-=* I LOVE MEN*=-
guys where do i fing this capyoda and greys crap? and where can i find the full revo kit? please help me find those things thanks a lot
Old Dec 30, 2003
JCiv03's Avatar
You should PM them.
Here's Capyoda's website: http://home.socal.rr.com/capyoda/
And to get grey's kit, just PM him.
Old Dec 31, 2003
u can buy the Revo SS from Robear Racing, he has a GB on them that i think ends tomorrow.
www.robearracing.com
