air bypass valve
Old Feb 25, 2002
Lianjie's Avatar
Lianjie is an unknown quantity at this point
air bypass valve
i have an AEM CAI, and i just got an AEM air bypass valve to protect against water damage, but it won't fit on.. i tried putting it between where the 2 pipes connect but it doesn't fit?!? am i doin something wrong?
Old Feb 25, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
what's the diameter of the air bypass valve?
i have injen CAI and the diameter is 2.5"..
Old Feb 25, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Yeah, you need to make sure the diameter of the bpv matches that of your intake. AEM makes it in 3 size, 2.0, 2.5, 3.0. If you got the wrong size just take it back and exchange it for the correct one. If you bought it online, then just take it to a local speed shop, they'll more than likely trade you.
Old Feb 25, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
Lianjie
i had the same problem
you won't get it to fit inbetween the two pipes because they are different diameters. i had to cut my aem intake on the top or high peice about one foot from the throttle body. i tried for about 2 hours to retro fit it with different hose clamps but it would not work. i recommend if you are going to cut to install your aem bypass that you cut where the silver warning sticker is.
hope this helps!
mievil
Apr 28, 2015 11:02 PM
ZSKCivic01
Jan 25, 2002 03:22 PM
vino
Bolt-on Engine Performance
Dec 25, 2001 07:18 PM
2k1civicman
Dec 17, 2001 06:18 PM
Jeff
Nov 25, 2001 10:01 AM
