[ Possible to use NSX auto-trannie's? ]
Has anyone with an automatic contemplated getting a NSX torqueconverter/transmission?
The gear ratios and final drive are MUCH better than ours:
Final Drive: 4.428
1st Gear: 2.611 - (42mph/6800rpm)
2nd Gear: 1.466 - (76mph/6800rpm)
3rd Gear: 1.025 - (109mph/6800rpm)
4th Gear: 0.684 - (163mph/6800rpm)
Rev Gear: 1.909 - (58mph/6800rpm)
I have looked on www.acuraautomativeparts.com, and the torque converter alone is around 1255$ USD.
I have heard of Eclipses and Lancers using the Vr-4 transmissions, is it possible to even do this with our cars?
Final Drive: 4.428
NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!NO! NO! NO! NO! NO!
<< "WTF? Final drive ratio and gear ratios have ABSOLUTELY NOTHING to do with HP and torque your freakin post *****...what is your problem??" >>
can you honestly say that altering your final drive ratio will make your car fast?
unless ur gettin rid of that SOHC ULEV VTEC-E, slapping on that NSX tranny won't do jack
thats what i wanted to know...right now the final drive in the automatic transmission is set to 4.36, with a 4th gear ratio of .967 makeing the automatics top out at about 117...theres got to be a better gear ratio that could be setup for our cars...
It wouldn't make a difference, because it would be sitting in a crate, idle...
There is no way you could shoe horn a C30/32 tranny into the engine bay of a D17 Civic...
Rebew - 58 mph in reverse...that would make for some awesome reverse 180 spins...
MyOtherRideIsBritney
I want her so bad...you don't even know
Zygrene
Mar 22, 2016 12:36 PM
