HKS turbo results question
Old Mar 1, 2002
2k2civic's Avatar
HKS said that they got about 30-40 horsies out of the turbo kit on the stock fuel system, correct?
Old Mar 1, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
yup...pretty sad eh?
Old Mar 1, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
is that all,,,,how much boost can u run on the hks systems?
Old Mar 1, 2002
Turtle's Avatar
Turtle is an unknown quantity at this point
I think it was 3-4 psi.
Old Mar 2, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
30-40 horse is correct
Old Mar 2, 2002
2k2civic's Avatar
And the only restriction was the fuel supply, correct? Everything else worked fine? I am thinking of putting together a turbo after the custom intake manifold and head p&p. I expect to hit 190+ on my LX with new exhaust system, turbo, intake manifold, p&p, ECU tuning. Does anyone think my number is too high? too low? This is gonna cost lots of cash and will take lots of time, but I will get there eventually. And after the fuel system problem is solved, then I can run 7-8 psi and 230+ hp. Yes? No? Any input from people who know what they are talking about. Please don't post if your talking on pure speculation. I don't mean to be rude, just need to cut the fat. Thanks.
Old Mar 2, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Why waste a few G's on a turbo that will output 20-30 at the most when you can spend half that and get a N2O kit?
Maybe cuzo f the beautiful sound of a turbo. N/M then. LoL
Old Mar 2, 2002
mattskav's Avatar
mattskav is an unknown quantity at this point
190 sounds right if you can get it done man, looks like there is going to be NO aftermarket support.
you're going to have to wait untill there are some electronics or schematics out to assist with timing on the new distributorless...
other than that you should be ok, people keep complaining about the returnless fuel line, but that shouldn't be too hard to fix, just change the pump out...those injectors wont even know what hit them.
what scares me is running much boost on a motor that has just about 10:1 compression....
I'd put good money on the motor popping.
For this car looks like there are 2 options, spray and NA Tune.
Old Mar 2, 2002
2k2civic's Avatar
I was thinking about going NA too....sleeved block 12:1 pistons, cam, ECU tuning (maybe an AEM EMS). Any suggestions?
Old Mar 2, 2002
Booohahaha's Avatar
BAD MON
haahahaa
cuz nos is like a drug.
well if u get a custom turbo then it be worth it more than the hks one
but the thing is
how are u gonna strenghten ur internals
there are no pistons or rings or anything out for our cars
gotta wait before that!!!!
Old Mar 3, 2002
2k2civic's Avatar
I'm sure I can run 3-4 PSI on stock internals. I should be able to hit 10 on stock internals with no problems (with proper timing and engine management).
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
carid
Nov 7, 2015 01:46 AM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Theshwartz35
Jul 18, 2015 10:49 PM
Jul 12, 2015 11:54 AM
