DX/LX to EX Cat swap?...Grey
Old Mar 5, 2002
mohawkboom's Avatar
My Friend has a Candian Si Model and he's getting the Magnaflow high flow cat for his car.. I was wondering if I Could Swap that EX cat onto my DX so that I Can use some 4-2-1 Headers [IMG]i/expressions/face-icon-small-smile.gif[/IMG].
Cheers
Mohawk
Old Mar 5, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
mohawk.. in theory.. it should totally work, since it's the same powerplant going.. but i'm no expert and i'm not gonna try and be one..
so.. someone feel free to help him out further.
Old Mar 5, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The differences between the D17A2 (EX) and the D17A1 are the exhaust header, the shield, exhaust pipe A (one with the cat), exhaust pipe B (the one between the cat and muffler), primary heated O2 sensor, and the secondary O2 sensor (and I assuming the harnesses for each).
Past that, mounting looks the same, even the brackets. I would say the hardest part would be the O2 sensors.
Old Mar 5, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
mohawkboom check the owners manual. it will show you in the emmissions section how the two cats are different. there is a second o2 sensor for the ex and cat that is not equiped on the base models. that should be the only major problem.
Old Mar 5, 2002
well if we don't need the second O2 sensor.. we just don't put it in... am i right?
Old Mar 5, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
yea..keep me updated on this..cause i want to get headers..but the cat is bugging me...
thanks.
Old Mar 5, 2002
mohawkboom's Avatar
I'm gonna check with the dealerhip see if the DX/LX's have the ecu wiring for the 02sensors.. I Know we don;t have the wiring for the tach..maybe we do for the 02 sensors..If all else fails I'm gonna switch to a Carburated system use the fuel injector holes for Nitrous...j/k (although I've seen it done to great effect (unit body CRX running high 11's)
Old Mar 5, 2002
Turtle's Avatar
Turtle is an unknown quantity at this point
I am now sure why everyone keeps saying that one of the models only has 1 o2 sensor. ALL MODELS HAVE 2 O2 SENSORS!!! The problems you will encounter by doing this swap are; the secondary O2 sensor on the LX/DX wont reach the location that it is on the EX/HX, and the EX/HX cat won't clear the LX/DX front sway bar. For the first one, you could either buy a o2 sensor extension (I think some aftermarket header companies make these), or make one of your own. If you make your own, solder ALL connections (this could cause incorrect o2 sensor reading and the car wont run as it should). For the sway bar, either buy a EX/HX sway bar (about $85 from Honda), or buy one from Neuspeed or someone like that.
Old Mar 5, 2002
Turtle's Avatar
Also, your exhaust systems will be different Buy a cat-back exhaust for an EX.
Old Mar 5, 2002
AlexLx's Avatar
AlexLx is an unknown quantity at this point
Every new car has 2 oxygen sensors. 1 before and one after. This is becuase they run off of the OBD-II ecu system operator. this is what makes ulev capable. much more efficient, get the carriage pipe with stock cat and bolt it to the headers. then just bolt up the exhaust. it will work the only thing you will need to do is lengthen the o2 wire for the second sensor.
Greenmonster
Aug 21, 2015 07:40 PM
2005seTO
Aug 18, 2015 12:45 PM
USCGBM
Aug 12, 2015 04:22 PM
PierrePierre
Aug 12, 2015 02:42 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
