Drain Hose Missing?
Old Aug 21, 2015
Greenmonster's Avatar
Greenmonster is an unknown quantity at this point
Drain Hose Missing?
Hey Guys,
I recently got out of my car and heard some popping noises, I looked under the car and I saw water dripping on the cat. Way back in the day the passenger side of the cabin started filliing up with water and I found out that there was a hose that was clogged under my car right above the cat. I pulled it off and lost it. Where can I find a new one and it is the condensation hose right?
Thanks Erbody
Old Aug 21, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: Drain Hose Missing?
Here..
http://www.collegehillshondaparts.co...ater-unit-scat
HOSE, DRAIN - 2001 HONDA CIVIC COUPE (80271S5A000)
may need the grommet alsoSEAL, DRAIN - 2001 HONDA CIVIC COUPE (79103S5A003)
Probably no more than $6.00 at you local dealer.
Old Aug 21, 2015
Thank you for the fast repsonse there. Do you think it would matter if I own a sedan if I get that hose?
What woule the grommet be used for?
Old Aug 21, 2015
RIPSAW's Avatar
I think maybe the grommet has a groove in the OD that holds it in the sheet metal. Then it's ID is what holds the tube in. If you can see the grommet in the floor pan, its still there. Go to the website above in post 2 and chose 2001 Coupe . It will be probably cheaper at your dealer since shipping will be high on a $2.00 part.
exiled1
Aug 8, 2015 06:09 PM
mcollins
Electrical
Jul 27, 2015 10:59 PM
Q-Bert
Jul 19, 2015 09:09 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
silentz
Jul 9, 2015 08:16 PM
