vtec switch point
Old Mar 1, 2002
Mitch's Avatar
Mitch is an unknown quantity at this point
vtec switch point
My lazy a$$ has not bought a helms service manual/supplement manual yet. Well, I am wanting to know the vtec switchover point for the 2k2 HX, and duh a coupe 5 speed. I did a freaking search a million times so don't give me no f-ing nooby this and that, flame this[IMG]i/expressions/moon.gif[/IMG]
Old Mar 1, 2002
SilverCivic2K1's Avatar
SilverCivic2K1 is an unknown quantity at this point
between 5200-5500 RPM's
Old Mar 1, 2002
SOHCScreamer's Avatar
SOHCScreamer is an unknown quantity at this point
4300RPM
Old Mar 1, 2002
Ichiban's Avatar
Ichiban is an unknown quantity at this point
the HX have the VTEC-E... its not really a true VTEC. under 2500 only 1 intake valve opens anything above and its like a normal non-VTEC engine.
Old Mar 1, 2002
crazyjetskier's Avatar
crazyjetskier is an unknown quantity at this point
my ex kicks in around 4000 to 4300
Old Mar 1, 2002
2001's Avatar
2001 is an unknown quantity at this point
I have an ex and I know it sounds like it hits at 4000 but the dealer said it hits at 5500..
Old Mar 1, 2002
i have a 5 speed EX and I know that V-tec kicks in at around 5300-5500. I'm positive.
Old Mar 1, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
I thought it was right at 4500?... [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 1, 2002
IonRays's Avatar
IonRays is an unknown quantity at this point
my vtec kicks around 4300.......hmmmmmmm wait a minute i dunt huv a vtec..oh silly me[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 1, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
mine sounds and feels like about 4500...depends on engine load and viechle speed.
Old Mar 2, 2002
Mitch's Avatar
<< the HX have the VTEC-E... its not really a true VTEC. under 2500 only 1 intake valve opens anything above and its like a normal non-VTEC engine. >>
WTF? Now here's a crack head. Uhm do you know anything about the last 16 years of Honda's 16v engines? Well, do you know about 2 intake valves and 2 exhaust valves for every cylinder, one primary, one secoundary for each intake/exhaust. The primary and secoundary have pistons in the rocker arm which gets oil pressure via the rockershaft, via the vtec solinoid, which is controlled by the ECU. Well, I have better things to do, later.
Old Mar 3, 2002
Mitch's Avatar
I am going to just get my own manual, I was thinking maybe someone with a HELMS manual would post some info. For all you retards saying I can feel it at 4k-4.5k rpm, you are just feeling max torq output. The automatics have a lower switchover point because they have a more closer cam lobe spec. So having the cross over at a lower rpm is smoother. With the manuals the vtec lobe is more significant and needs a higher rpm cross over for less lag and faster acceleration. I know it's more than 5k rpm and less than 5.6k rpm. Fuel cutoff is at 7,200 rpm. But like I said at the top, I'm going to just get my own damn manual. Thanks for all the posts though!
Old Mar 3, 2002
Ichiban's Avatar
<< WTF? Now here's a crack head. Uhm do you know anything about the last 16 years of Honda's 16v engines? Well, do you know about 2 intake valves and 2 exhaust valves for every cylinder, one primary, one secoundary for each intake/exhaust. The primary and secoundary have pistons in the rocker arm which gets oil pressure via the rockershaft, via the vtec solinoid, which is controlled by the ECU. Well, I have better things to do, later. >>
First of all you obviously don't know your facts...second I have posted on this subject many times...search for it... I know they have 16 valves And I know how VTEC works...but VTEC-E on the HX is different then the regular SOHC VTEC. For the last freaking time. Get your information right.
Old Mar 3, 2002
theSHADIEST's Avatar
theSHADIEST is an unknown quantity at this point
dude do u mean haynes manual...if not then my bad...just never heard of a helms manual...is it something i should know about....hey gotta be in that loop of info
Old Mar 4, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
Guys, I got a vtec controller and it shows that it opens Not all the times, depends on some factors, but if you are in first gear, it opens at +-3500. Not at 4000,4500,5000 or what ever. Other way to check it is hooking a led into the vtec wire. If you are in neutral, vtec won't open. Again it depends on driving conditions. There is not a pre-set engagement point! See it by your self! hook a 12v bulb or a voltmeter to the vtec wire to see what I am saying.[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Mar 4, 2002
Erichyung's Avatar
Erichyung is an unknown quantity at this point
the point is... we can't even hear our vtec because it sucks. we can't feel it or hear it. therefore, it's like having no vtec.
Old Mar 4, 2002
Ichiban's Avatar
Yeah that kinda makes me mad...but oh well i guess as long as we know we have it...I don't think its that great anyways, I would rather have a stock turbo on like a eclipse or something over the VTEC.
Old Mar 4, 2002
Mitch's Avatar
Well if you want to feel the vtec engagement then buy a Toda, Jun, or a Crower cam with the largest profile you are willing to cope with.
Old Mar 5, 2002
Erichyung's Avatar
did u say cams??? haha i doubt they'll make it for our car. maybe in 4~5 years.
Old Mar 5, 2002
Mitch's Avatar
<< did u say cams??? haha i doubt they'll make it for our car. maybe in 4~5 years. >>
Yeah ha ha, if you have the bucks and know about designing cam specs have them make a custom cam.
01civyv3
Jun 2, 2015 05:21 AM
werdnahall
May 17, 2015 11:37 AM
tmort
May 11, 2015 07:13 PM
CarbonFiberSi
Apr 21, 2005 07:50 AM
Jimmy24
19
Feb 19, 2002 12:59 PM
