Question AEM CAI w/Bypass
Old Feb 27, 2002
cro2k2civicla's Avatar
cro2k2civicla is an unknown quantity at this point
I have done a search on this and have found mixed reviews. My question that I am trying to get answered is if adding a bypass to the AEM CAI would result in a loss in power or sound? I will be placing it between the pipe connecting the throttle body and the pipe connecting to the filter. I am not going to cut the pipe as stated in the directions. On my setup it fits securely. So again my question is if I set it up this way will I loose power or sound???? Thanks
Old Feb 27, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
You will lose a tiny tiny bit of power, and a tiny tiny bit of sound....probably not even enough
to notice....but you will notice if your engine sucks up a puddle from the side of the road, and
you engine chokes on it and dies.....for the tiny loss of power and sound, it's better to be safe then
have a blown engine....
Old Feb 27, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
i agree w/antidote11 for the loss of maybe 1 horsepower its peace of mind knowing you'll be okay in bad weather. it still better than stock
Old Feb 27, 2002
Lianjie's Avatar
Lianjie is an unknown quantity at this point
ya u definately lose sound i think... cro2k, what size did u order??? i had to shave the rubber insert in the bypass valve to make it fit to the pipe going vertical.. it was a pain, but it fit fine connecting to the throttle body pipe.. hmm :\
Old Feb 27, 2002
Mapes's Avatar
Mapes is an unknown quantity at this point
Cro, could you post a pic of your setup....im gettin a aem cai....dont wanna cut my pipe...if you can great, if not no prob...
Old Mar 1, 2002
Mapes, this is my setup. I decided against the Bypass. Actually its on Ebay as we speek. The yellow arrow shows where I was going to install the bypass. The one I was sent fit perfectly here but the instructions called for cutting the pipe. At first I didnt like the CAI, it actually felt slower. I had reset the ECU as stated here and it was sluggish. After about 200miles its back to normal and I can tell a big increase with the CAI. I love it now and don't want to adjust anything on it. I have the filter a hair above the splash guard. I highly reccomend getting the AEM CAI, but if you do the install yourself I dont reccomend resetting the ECU. Just let it be and it will adjust itself, maybe you can avoid the sluggishness......
Lata,
Ozzy
Old Mar 1, 2002
Ummm if you dont want to click the link Ill try again.....
carid
Nov 7, 2015 01:46 AM
naokigoffi
Aug 30, 2015 06:19 PM
spyder13
Jul 31, 2015 06:31 PM
Misfit2613
Jul 30, 2015 09:49 AM
Theshwartz35
Jul 17, 2015 11:13 PM
