Tuner Lug Nuts?
Old Mar 3, 2002
klam's Avatar
klam is an unknown quantity at this point
Tuner Lug Nuts?
I'm shopping around for my summer wheels now, but I come across wheels that need "tuner lug nuts".
What are "tuner lug nuts"? From pictures I see, they are just smaller and usually used for aftermarket wheels. Is there anything I should know about them? Can you get tuner lug nuts with a unique pattern (like regular wheel lug nuts) to prevent theft or do they all come in a standard attachment pattern?
Old Mar 3, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
tuner lugs, i think, are longer and i think some have different heads so you use like an allen type set up so the socket goes on the inside of the nut not the out side. i could be way off.
Old Mar 3, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Since this is a problem I just had to deal with, so I will offer all the help I can. If your wheels require tuner lugs, that means that the wheels have the lug portion inset into the wheel. They also have a minimum of clearance and require thinner lugs, plug an ordinary socket will not fit into the hole.
Tuner lugs use a key, rather than using a socket. The least expensive use an allen type of key. These are the easiest to find, but are cheap and expose the lug to the outside world.
The best lugs I found were made by McGard. You can check them out at www.mcgard.com
Plus not only will you find some cool lug nuts, even colored ones, they will also offer locks to keep the wheels on YOUR car.
Old Mar 3, 2002
klam's Avatar
Thanks for the help! I guess this was an unexpected cost.
Old Mar 3, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
Gorilla makes a good set of tuner lugs also.
Old Mar 3, 2002
VTEC808's Avatar
VTEC808 is an unknown quantity at this point
Some tuner lug nuts have a wrench that goes inside the head of the lug & some have a wrench that goes around the outside of the lug nut. I have had both.....My Konig Monsoons came with tuner lugs that had the wrench go around the outside of the lug nut & my Enkei Shoguns have lugs where the wrench fits inside the head of the lug nut. They are basically just smaller lug nuts. Any wheel shop can tell ya what type of tuner lugs you need for a particular wheel.
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
AffliictiioN
Sep 16, 2015 02:21 PM
siliconvalley
Sep 15, 2015 09:48 PM
