Washing with an AEM CAI
I just installed my CAi and am wondering if there are any guidelines you all might have for me when it comes to washing my car? Should i avoid spraying in the wheel well?
And will installing the bypass valve change the sound of the intake? I ordered one but dont want to install it if the sound is going to be altered greatly.
Thanks.
Thanks.
Well on my car i also have a CAI but have not had any problems with the filter getting wet when washing. You don't really have too worry about it cause on our cars the filter its self does not go in the wheel well, it sits right in front of the engine. I have not had a bypass valve on for almost 6 months and have not had a problem yet and that includes driving through a terencial down poor where u can barley see the road. I have also drive through some puddle that might have been bad if i was accelerating but if the filter just get's wet it won't really do anything cause the intake tube gets warm enough that if any little bit of water were to get into the intake tube the heat would prolly just make it evaporate. Hope that helps.
I have not had any problems with the CAI when washing my car. If it gets wet it usually dries by the time I finish washing my car. I do not have the bypass valve and I too have been through some heavy rain and have not experienced any major problems. I did however notice that at times when it starts to rain hard my car makes a poping sound. I figured out that it was coming for the CAI. It acts like when you finish a soda and you continue to suck on the straw, that is the same type of sound I get. I was scared the first few times I heard it but I guess you just have to be careful. As long as you don't get any water into your engine you'll be OK.
I don't think you'll have any problems washing your car with the aem cai in there. Its not in the wheel well like it is on some other cars. Its down in front of the transmission. And even if it was in the wheel well, I think it would still be fine. My b/f's had the cai on his gsr for over a year and has never had any problems with washing his car. Don't worry about it. It'll be fine.
Retired Super Mod and STILL Pimpin' Yo Mama
My question is, are you washing your car with the engine running? If the filter gets moist from overspray, I doubt it'll be enough to damage the engine...
Actually i haven't run a bypass valve at all. I even power wash my car and i still haven't had a problem with the filter getting wet. And like i said b4 if u do get a little moisture in the tube it's self the tube gets warm enough that the little bit of moisture that might be in there will evaporate b4 it even get's close to the engine. The bypass valve is really only good if u put the whole filter underwater and then hit the gas that is what it was designed for. So if u really aren't driving through puddles u really don't need it.
