HYPERBLINKER on sedan,anyone?i tried but i failed
Old Feb 20, 2002
zackde's Avatar
zackde is an unknown quantity at this point
help guys.....
the DIY HYPERBLINKER by phong was awesome & easy but when i checked my sedans fuse box d switch relays are diff. i tried to trounbleshoot the matter by pulling out each relay one at each time (i think there is 6 or 7 relays on the fuse box) WHILE MY SIGNAL LIGHT IS BLINKING thinking that if i pulled the right relay the signal will stop (am i right?) but to my demise the signal keep on blinking, anyone got an idea which relay is it on the sedan to modify? is it located also in the fuse box just like on the coupe?
thanxxx
[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Feb 20, 2002
black's Avatar
black is an unknown quantity at this point
trial and error sucks man, hope you get a reply from someone with the facts.
i have a coupe, sorry. mine is under the stearing wheel though. It should be an identical piece more or less anyways.
oh well, good luck
Old Feb 20, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
i think the site has a better diy for you.
leave the car off.don't even put your key in the ignition.
turn on your hazard lights.
follow the clicking under the steering collum.
the easiest way to get at the relay is to lay on your back on the floor boards feet on the chair
the relay you have from hyper blinker looks just like the oem one from honda.
its hidden like a ninja above and to the right of the fuse box below the steering wheel.
once you locate the relay turn off your hazards. this relay removes just like a fuse . only more stubborn give a good pull and it will slide right out . replace it with the new relay and its a done deal.
good luck
Old Feb 20, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
The relay is in the same position as the coupes. It's just that the relay itself is different. I don't know why, but it stumped me when I tried. Have you tried looking for all possible resistors on the relay? That is the only way that you'll be able to do it. I'm gonna have a chance to try making one for my friend's sedan again in the near future, so I'll report back afterwards if you guys haven't already figured it out...
Old Feb 20, 2002
netcbc's Avatar
netcbc is an unknown quantity at this point
i bought one and it worked
Old Feb 20, 2002
zackde's Avatar
DAMN HELL hard to pull that F**KNG relay under the steering wheel!!
i might tell u guys.......buy a new hyperblinker relay rather than DIY!!
i almost break my back pulling that damn relay doing it i a lying postion w/ my head under the steering columnn then when i opened the relay, there 3 resistors, 1st tried the smallest resistor, i soldered a 150k resistor & F**CK it didnt work!! i tried the other two & nothing happened just pain im my back now, ill just buy rather that torture myself w/ DIY
any idea why it didnt work??
still the 150k is in my relay & i dont want to pull it agaiun IT IS SO DAMN HARD, ill just reploace it when i got a new one
NETCBC..........
where did u got ur hyperblinker??
how much??
thanxx
Old Feb 20, 2002
netcbc's Avatar
[IMG]i/expressions/moon.gif[/IMG]
you should haev done a search first!!! theres a screw near the relay box and you can take out the screw then you can pull down the whol relay box, then taking it out is really easy!!!
Old Feb 20, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
Sorry to hear the sedan is causing so much trouble... Sounds like you put a good effort to trial and error.
www.hyperblinker.com
This should help fix the hyperblinker problem
Old Feb 21, 2002
zackde's Avatar
anyone here who is successful in DIY HYPERBLINKER in sedan??............there are 3 resistors in the relay & there is no indication/print or whatsoever which is R1............3 resistors inside, 1 big, 2 small
[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jun 24, 2002
Player1's Avatar
Player1 is an unknown quantity at this point
I've just been reading about the hyperblinkers and hopefully you've found the DIY thread for the sedans by now. But in case you haven't, here is the sedan link. I didn't post the direct link because this guy deserves the credit for finding it.
JetsterDajet
52
May 8, 2016 12:11 AM
Sep 27, 2015 11:33 AM
Ultra Havoc
Sep 9, 2015 10:58 PM
Stock 99
Sep 5, 2015 06:06 AM
dantheman42
Sep 4, 2015 01:10 PM
