rattle
Old Jul 26, 2005
allmotor's Avatar
nor cal 7thgens
rattle
i know this has been covered but i finally got around to trying to solve the problem. I kept hearing annoying rattles coming from my exhuast and it sounded like the heatshield was doing it? Well i took off the whole heatshield,and took off the 2 bolts again off the cat and put them on tight and i started teh car and at first it sounded good , but then it came back and i cant stand it anymore. I was wondering if anyone here knows what else to do? I remember when i first got the car i took of my exhuast from the cat (vp) and i now am wondering if maybe there was an exhuast gasket of some sort in between. If not then what else can it be. Every time i get out of first or reverse its makin this rattle and its gotten to the point were my family calls me an okie and people everywhere stare at my car in a bad way like its ghetto.
Old Jul 26, 2005
streetglower's Avatar
check your cat converter. I see this all the time at my work. If you rev up the engine, do you hear it? the insides of your cat might be gone.
Also try getting under the car and hitting everything with a mallet and see where the rattle is coming from.
Old Jul 26, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
Originally Posted by allmotor
...like its ghetto.
Matt's Ghetto!!! LMAO!!! Hey are you ever gonna get back to me about doin the safc or do I gotta !! Maybe we can look at that exhaust issue as well!! How are the plugs doin for you?? Call me and we can get that shiet goin!!!!
Old Jul 26, 2005
IDQcivic's Avatar
IDQcivic should not be trusted
Yeah check your cat, mine had something rattling in the cat which was causing my rattle, good luck man!
Old Jul 26, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
I have the same problem. But mine only happened when I put the cat delete pipe on. I know its the sheild some where. But I have been lazy....plus i have new sway bars comin ill dig into then. Btw yea I have some poeple lookin at mee too......its like you wanna say wait nono i swear its not a pos i just have not fixed it yet!
Old Jul 26, 2005
allmotor's Avatar
nor cal 7thgens
yep thanks guys. Yeah justin i sent u a pm
Old Jul 27, 2005
Mike813's Avatar
Mike813 is an unknown quantity at this point
try checking under the car when you leave it at reverse,
the pipes flex when you put it in and out of gears, causing a pipe or your exhaust itself to touch the plates causing it to rattle, my accord back then had the same problem, and i had to get a flex pipe to fix the sound, either that or get lower hangers to keep the rear side of the exhaust away from the heat plates. but my vehicle was lower than 1.7 back then so lower hangers was a nono.
mistahlorax13
21
Nov 18, 2015 12:47 PM
rovafa2002
Sep 28, 2015 06:57 PM
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
Yazan93
Jul 14, 2015 08:56 PM
