Problematic intake air temp sensors?
I'm having an intermittent CEL with a high signal reading from my intake air temp sensor. Just wondering if anyone has had problems, and is this at all common for these to fail. It's a 01 Coupe VTEC.
like gearbox said. most likely it is the sensor itself. If you want to check, see if you have a 5 volt reference signal running to the sensor. If you do, the sensor is the problem, if you dont, you have a open in the wiring between the PCM and sensor, a bad ground, or problems with the PCM.
ORskier
May 7, 2015 04:54 PM
Blaster30
Apr 22, 2015 12:21 PM
