04 Mt
Old Aug 1, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
04 Mt
How much hp can an 04 manual transmission take before it goes out???
I know.....just some educated guesses or someone with experiance with a tranny going bad would be nice!!!
Old Aug 1, 2005
Michalo187's Avatar
Abortion Survivor
what do you mean? how much do you have on wheel horsepower? what car do you have?
Old Aug 1, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Ohhh.... about 128 or so....
Old Aug 1, 2005
jackburton's Avatar
^huh??? u joshin me?
^^civic ex 04, stock, just curious.
clarifiacation- I know axles can only take up to around 200 hp, head gasket around 10psi maybe less, clutch wears after about a month of being boosted. Not sure about rods but am guessing above 12 psi they aint gonna cut it. Also our block probably cannot take more than 250whp, even with alcohol. Rings too and pistons.
Now how much HP/PSI can manual gearbox take?
Or how long can you boost until it is chewed to hell?
stories of MT exploding would be nice, anything really.
I know there are not a lot of people with 04 and boosted so any 7thgen would be fine. I was also wondering how many people have transmission problems, other than clutch, and of course auto.
I know it is different for someone who drives like a bat out of hell all the time compared to someone who likes to cruise alot, but any experiances or estimates would be nice.
Thanks
Old Aug 1, 2005
Michalo187's Avatar
Abortion Survivor
OOOOOO well just modify the clutch and the flywheel there is members with a better clutch and flywheel i have the exedy organic and streetlite flywheel and it works great my head gasket recently blew but they blow when you lean out. The auto guys here with turbo need a tranny cooler and i don't know what else they do but some don't run as much boost but there is a member running 12 psi with an auto it just all depends i guess all the cars are different
Old Aug 1, 2005
AlienX's Avatar
AlienX will become famous soon enough
its not a question of hp, but tq. A clutch upgrade would be needed for something like a turbo, but otherwise I havnt haerd much bout people blowing them.
Old Aug 1, 2005
jackburton's Avatar
I know about the autos-some have slipping some donnot, with or woth out trans cooler-I think it is how they drive, personally.
I just never hear of problems with MT, and was curious about what its limits are.
Old Aug 1, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
from what i understand 250hp for a stock tranny. anything higher is too much for it.
Old Aug 1, 2005
jackburton's Avatar
^where did you get this info, i want some facts here ninja boy, im on to you
Old Aug 1, 2005
MajinB's Avatar
ok hold on i will find it
EDIT: found first post on second page. discussion about max hp possible on d17 motor
http://www.7thgencivic.com/forums/sh...=219612&page=2
Old Aug 1, 2005
Jrfish007's Avatar
That's what I was going to say, hp doesn't kill, torque does. From what I have seen the only thing that really consistant kills manual tranies is the driver. The 3rd gear syncro grinding is generally the first sign that you suck at shifting (some are just goofy and grind for no reason) but if you shift right you won't have any problems (after an upgraded clutch).
Old Aug 1, 2005
jackburton's Avatar
iwhoops!!!
Old Aug 1, 2005
jackburton's Avatar
i think the 1st to 2nd is the hardest. Due to traction.
I used to have a problem with 2nd-3rd the first year i drove,not with grinding, just with making it smooth, but i have worked out the kinks, its hard to explain, you just gotta slip it in there
slip the jab rock!!!
Old Aug 1, 2005
jackburton's Avatar
so barney had 300 hp to the wheels with stock gearbox???
Old Aug 1, 2005
Jrfish007's Avatar
2-3rd was the one I was refering to, many people have complained about that one. I had the same problem you did, then after some time I just learned how to "slip it in" as you say.
