Can I skip getting a wideband if I run emanage?
Old Jul 31, 2005
Rufus's Avatar
I just got emanage for my turbo setup and since i can use a laptop can I skip getting a wideband?
Old Aug 1, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
no.
wideband very important, get one.
Old Aug 1, 2005
Jeromie's Avatar
Jeromie is an unknown quantity at this point
if i get a wideband do i need a new a/f gauge? or can i still use my cobalt gauge?
Old Aug 1, 2005
Rufus's Avatar
Why can't emange show the same information via a laptop?
Old Aug 1, 2005
HyaBoosta's Avatar
cause it only adds fuel it can't tell how it's burning. it's not connected to the o2 sensor. even if it was that is only a narrow band signal
Old Aug 1, 2005
k20txem2's Avatar
k20txem2 is an unknown quantity at this point
you dont even need an A/F gauge. its just fancy little light show or what ever. Get something useful like Oil Temp so you know when your about to fry a ring or two.
Old Aug 1, 2005
djmota's Avatar
yes you can. most wideband devices allow for an analog output to make your af guage actually acurate.
Old Aug 1, 2005
AlienX's Avatar
AlienX will become famous soon enough
if u have a wideband A/F guage you will need a new guage. There is a way to mod the autometers(cobalt ect) to have wideband readings and it is not just a light show.
Just so you know something k20txem2. Narrowband will only tell you if u are Rich, perfect, Lean. Thats it, there is no way you can really use it to make accurate adjustments.
A wideband w/a proper guage will be able to show how much you are really off in aspects of lean-rich. This way you can add/remove fuel to mix a perfect 14.8:1 ratio.
Do some research before misleading others, AEMs website provides a grafical explanation to what the diff between the two is, so you should head there. As for me, im not gonna go into much details bout it since I only have 1 hand to type w/since I had surgery on the other.
Old Aug 1, 2005
jackburton's Avatar
boost>wideband>oil temp>other guages
Old Aug 1, 2005
2K1Civic17"Gabe's Avatar
my narrowband gauge has the capability of being hooked up to a wideband sensor. Just depends on what gauges you have I believe, some or most will let you hook up your 100 dollar gauge to a real sensor. But its best to have everything to get a complete accurate digital readout.
mattdoc
Mar 14, 2017 12:10 PM
Supramk3
May 11, 2015 07:55 PM
JoeB16
61
Oct 16, 2003 07:58 PM
avenger
Jan 30, 2002 04:53 PM
Desi
Nov 14, 2001 01:58 PM
