Tightened E-Brake, any opinion?
Hi guys!
I just followed Grey's DIY to tighten my E-brake from inside my car...
now, the question is........
currently, i need approximately 5~6 clicks (pull slowly up) to engage the E-brake...do you guys think it's normal or did i tighten it too much?
i really feel nice with it now....cos' it only needs short pull...and the e-brake itself doesn't wiggle around anymore...the problem is....i'm afraid that i over tighten it.........and might be the cause of the "squeeking" noise from behind when i push my brake to stop...
thanx!
-cal
thanx!
-cal
^lol....good to hear..
but anywho...he (grey) mentioned there to jack up the rear before doing the DIY....is it for this DIY for or the star rachet (inside drum) DIY?
i didn't jack up my car when i tighten the ebrake nut....
Touch it... He won't bite, He'll just come at you pretty quick.
you don't need to jack the car up to tighten the e-brake cable... If you had the tires off the ground chances are you would make it too tight. With the car level, you can make it just perfect.
you dont need to tighten the ebrake from inside the car. Just jack up the rear, remove the drums and adjust the star adjuster to set the clearance between the shoes and drums. You should feel a slight drag. That will set also the parking brake. Mine has 1 click.
^^i don't really need to tighten the star cos' that's not really the problem.
the problem is within the e-brake handle......it's very loose.....
so, the inside DIY fixed it promptly... =)
master of the culinary martial arts
I tighten my e-brake (drums on rear) by driving in reverse at the speed of a jog, then stopping the car by pulling on the e-brake. 1-3 times and my e-brake feels like new.
Eeeh... it works for me.
^hm..
kind of WORD to me....but there's a thread that discusses this earlier...
he mentioned that the mechanic on a shop are the one who told him about this trick...
it's supposedly works to adjust the star rachet by "cheating" it.....as u all know, braking after reverse also known to auto-adjust the rear brake..
anywho....still, this trick has nothing to do with the e-brake loose handle...
2002ExCivic
22
Sep 28, 2015 08:29 AM
blward6
Sep 16, 2015 05:32 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
