Squeaky Rear GroundControl...
Like the title says..my rear passenger GC is squeaking...replace the o-ring in between the sleeve and strut, started again!! Removing the set-up is not exactly cool to do right now...does anybody have any suggestions of things I can do to stop it? I though of silicone or WD-40 what do you guys think? Any input would be awesome!! Thanks in Advance!! -Justin
its not the gc. its your shock. namely the lower bushing in the rear shock that the bolt goes thru. the angle it sits at makes the bushing shift abit in the shock this starts the squeeking sound when you go over bumps. you can fix it by pulling the strut assembly out, then using a socket and a block of wood and a hammer. hammer the bushing until its straight again then grease it and reinstall.
Kick *** rep for you...thanks!! I did not think of that!!!!
edit: You must spread some Reputation around before giving it to djmota again.
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
