Battery Light Issue
Old Jul 14, 2005
Karumba's Avatar
Boredom causes changes ;)
Battery Light Issue
Have a buddy who is having problems with his battery light staying on ..
He's changed the alternator and the battery .. he's checked the grounds near the motor .. everything looks fine. Unfortunately the light stills remains on.
Any pointers/trouble areas to look into?
Old Jul 14, 2005
battery light means charging system problem (alternator). Hook up a volt gauge and see what the readings are.
Old Jul 15, 2005
Karumba's Avatar
Originally Posted by Shaiitake - guy with problem
the gauge listen between 13 to 14 volt and I changed the alternator ... my battery are ok and she stay our charge at 12.9 volt i dont understand that very strange
Basically
Old Jul 15, 2005
shaiitake's Avatar
shaiitake is an unknown quantity at this point
Hello i'm the body that a have the trouble ... my gauge on the battery listen 12 volt when the car sleeping and when a start the engin my gauge listen 14 volt. After if i remove the negative when the car run the alternator do our job becose the engin run always ... last week we change the timing belt and a couple days after my battery led turn on ... i suppose the belt of my alternator come loose! it is the problem? or it is a nother thing i dont no??? please averyone help me
Old Jul 15, 2005
if it happened after, then yea the belt might not be tight enough. Otherwise the alternator isn't working. What does the voltage read now after the car is on?
Old Jul 15, 2005
shaiitake's Avatar
13.5 volt presently when the car runs
Old Jul 18, 2005
shaiitake's Avatar
Any person have another suggestion ?
Old Jul 18, 2005
shaiitake's Avatar
it is possible that the multiplex control unit system have any problem ??? or it have any report with my problem?
Old Jul 18, 2005
Bigfella's Avatar
Bigfella is an unknown quantity at this point
Is the battery still going flat, or is it running ok??? I am no expert on auto electrics but there is something in the the car that monitors the current produced, hence too much or too little and the light comes on, propably the device that i am trying to describe is at fault. No idea what its called.
CarStuff
Dec 6, 2020 12:52 PM
trellex
May 24, 2015 04:39 PM
WLakers
May 4, 2015 06:23 PM
tylerginevan
Apr 27, 2015 12:29 PM
SSMatey
Apr 13, 2015 06:09 PM
