headswap n cams ?
Old Jun 23, 2005
dnbguy86's Avatar
dnbguy86 is an unknown quantity at this point
headswap n cams ?
Alright, so i was thinking about putting a ex head on my lx, and then installing crowers new cams and spring set for the a2 head. Is this a worthwhile upgrade if i can get a ex head for 200$, vafc for around 300+ or so, and then another 500+ for the cam set ? I know my car wont be a racecar or anything, but some extra umpphh would definitely please me... any comments ?
Old Jun 23, 2005
fuzzylogic426's Avatar
fuzzylogic426 is an unknown quantity at this point
thats actually what im planning on doing right now. but i havent had any luck finding any ex head's.
Old Jun 23, 2005
dbzkid84's Avatar
dbzkid84 is an unknown quantity at this point
I'm planning to do the same thing... I am also looking into buying a spare short block and resleeving it with darton d16 flange sleeves so that way the engine can handle more boost. But i have a lot of research to do.
Old Jun 26, 2005
Nokturnl's Avatar
Crawlin Similar To An Ant Low To Da Earth
Nokturnl has a spectacular aura aboutNokturnl has a spectacular aura aboutNokturnl has a spectacular aura about
Crower stage 2 cam and springs/retainers going in this week.....ex head lx block...must b a good idea!!
Old Jun 26, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
I kind of want an LX head to go turbo... its better for boost.
Old Jun 26, 2005
civic01vtec's Avatar
I can't believe ppl actually still wanna waste money on a all-motor sohc set-up.
Old Jun 26, 2005
Not really........the head has no affect on compression. A EX motor has higher compression vs. a LX/DX. By swapping a EX head to a LX head you are doing nothing but losing vtec while compression remains the same.
Old Jun 26, 2005
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
^^ true
Old Jun 26, 2005
Blahman240's Avatar
hmm...
Old Jun 26, 2005
Echelon04's Avatar
You want a higher compression with Turbo right?
Old Jun 26, 2005
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
hmm...
Your also losing roller rockers which are better for higher reving.
Old Jun 26, 2005
dnbguy86's Avatar
Unfortunately sir, you are wrong. Ex's actually have a compression ratio of 9.9:1 compared to the lx's 9.5:1. I seriously doubt honda choose to go to different pistons in the ex, so its all in the head that changes the ratio. And i think the reason that one guy wanted a lx head saying its better for boost is because a lower compression ratio is less prone to detonation than a higher ratio.
Old Jun 27, 2005
Logan3024's Avatar
Um you sir are a moron. Thats the compression ratio of the pistons, which is located inside the block, not the head.
Anyways the intake ports are smaller on the LX engine, dont see how this ='s better for boost.
Old Jun 27, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
No. You're wrong. Pistons dictate compression differences on d17's.
Old Jun 27, 2005
spoonEM's Avatar
omgwtfbbq mod.
well, which is it. lol. I have an 05 lx and I eventually want to do a turbo setup. Would it be posible to do it on my lx? Or should I do the head swap?
Old Jun 27, 2005
Vantage's Avatar
Vantage should not be trusted
You want lower compression. but it wont make to much difference unless ur running super high boost, or have 11:1 or HIGH compression.
Dont waist ur $$ and time on swapping an EX for LX head, u will probably lose power. Vtec CAN be good wwith a turbo, even if its higher comp. u will only LOSE power with a turbo if u have to much high compression, then its a bomb. if ur gunna keep ur d17a2 below 10 psi, the Vtec head will be fine. Same thing about Tranny's, unless ur over 10psi, the shorter EX tranny will work fine, if ur going super high boost, start with the LX with lower comp, and longer gears.
Old Jun 27, 2005
spoonEM's Avatar
omgwtfbbq mod.
sweet. Ya, i hae the D17A1 non-vtec, with a manual tranny. So im stoked to hear i can still do a turbo set-up without swapping the head. Anyone know of a setup for my car? Or am I going to have to make it custom?
Old Jun 27, 2005
Blahman240's Avatar
noooooo You do that and your engine magically stops working.
Old Jun 27, 2005
Unfortunately sir, you are a dumbass. I have built more motors than times you have touched yourself
Old Jun 27, 2005
nickm748's Avatar
Wow you built over 100,000 motors!
thats impressive
Old Jun 30, 2005
runner1738's Avatar
im almost thing swapping hte whole ex engine in, because if you only do a head swap then the only difference is the ecu right or is there something else? but if your gonna do a head swap please do an exhaust one as well
Old Jun 30, 2005
Graphicdude's Avatar
Creative Mind Extraodinare
Graphicdude will become famous soon enoughGraphicdude will become famous soon enough
All this talk of head swap, compression, turbo etc is making my head hurt! I would like to know WHO on this site has the brains, credentials and the know-how/experience/wrench head, to put all this heresay to rest and give the REAL low down on what works best, what is **** and what doesn't fvck up your motor, whether it be a non or Vtec SOHC???????????
PLEASE someone has to know this shait and is looking at this post right now and saying "what a bunch of dumbasses....." or something like that.
Honestly, i am going to go to a reputable shop in my city and get some answers from people i know will not bullshit me. Listening to everyone here scares me and really makes me hesitant to do anything. Know one really knows whos legit and whos bullshit? Like I said it is all heresay.
Old Jun 30, 2005
Drk01Civic's Avatar
I just ordered my Crower stage 2 turbo cam, springs, & retainers today. Tomorrow I'm dropping off my EX head to Exospeed for Port, Polish, Valve job, etc. I should have everything back and ready to install in 2 weeks. Dyno soon to follow install. I can't wait
Old Jun 30, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
you so have to tell me how that goes im going turbo real soon in my lx
ricer_em2
May 11, 2016 08:09 PM
pilebuck13
Sep 21, 2015 10:45 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Juanb24
Sep 15, 2015 12:39 AM
CdnRD
Aug 21, 2015 11:42 PM
