Help......pcv Valve - Check Engine Light
Old Jul 31, 2005
CVENESKY's Avatar
CVENESKY is an unknown quantity at this point
I Have A 2001 Honda Civic Lx, 1.7 Sedan
Should The Check Engine Light Come On Due To A Bad Pcv Valve.
If It Does Not, Could A Scan Diagnose A Bad Valve.
Thanks For Any Response
Old Jul 31, 2005
I don't think our cars use em anymore. The pcv system is just that hose connecting the crankcase to the intake.
Old Jul 31, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
Just like gearbox rightfully said...no PCV!! What problems is the car having??
Old Aug 1, 2005
etdigitalis's Avatar
etdigitalis should not be trusted
have you done a scan yet?
any auto parts chain should be able to hook you up for free and it will tell you exactly what sensor is causing the CEL
Old Aug 1, 2005
streetglower's Avatar
Our cars do use PCV valves. There are 2 OBD 2 codes associated with the PCV system too. Here:
http://www.hondaautomotiveparts.com/...=BREATHER+TUBE
number 4 in the picture is the PCV valve. Every car uses sometime of PCV system.
Old Aug 1, 2005
hmm! do you know if its easy to change? The dealer says the new civics don't have em?
Old Aug 1, 2005
Wow I was unaware...thanks for the info!!!
Old Aug 1, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Never trust a dealer.
ANY TYPE OF DEALER!
Old Aug 2, 2005
ANY TYPE OF DEALER!
In a since I agree with that. I work for one and have seen some pretty fuked up ****. Anyway, I dont know why the dealer says our cars dont use them. Is it just me or does honda seem to have technicians and advisors who have no idea what they are doing or saying? When I was at honda 3 weeks ago for warranty work, my advisor told me my civic doesnt have lower control arms. WTF!!!
Old Aug 2, 2005
They told me the fuel filter isn't a servicable item on our cars?? haha. So is that pcv valve easy to change then?
Old Aug 2, 2005
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
The fuel filter isn't really serviceable, unless you want to get inside the tank to do it. The maintenance schedule describes it as a "lifetime" item.
Old Aug 2, 2005
well alot of people have diyed it. and it does gt clogged. I don't see how it would be different from any other car fuel filter.
Old Aug 2, 2005
actually are filter is alot different then others. Most are inline with the system and require you to disconnect 2 lines from the filter and remove it. Takes usually 15 minutes to do.
Ours is inside the fuel tank attatched to the fuel pump. you have to disassemble it from the pump and replace. Plus the electrical connection for the pump is on the filter. Plus it looks way different.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
