Dash Lights
Dash Lights
I have a 93 Honda Civic EX that I just purchased the dash light did not work. While i doing some testing I dicovered that when I removed the switch on the dash that dims the dash light it started working. Well i thought it was just a bad connection and i clean it and put it back together, but the next time i tryed to use them they would not work so I push in on the roller part of the dimmer switch and the lights started working again so i went to the junk yard to get another switch because i figured the switch was bad, well it work go for a couple of day's and it doing the same again, has anyone else had this promblem because I hate to go and buy a $100.00 switch from the dealer and that not be the promblem.
Maybe you could take the control and the harness/plug out to isolate which part is defective.
Online parts sources are much cheaper than the dealer, ( I could not locate your part though, any part #s available ?)
It will not work without the dimmer. I have no part number there is no number listed on the part.I have check the connection on the back of the switch and no bad or loose connection.There are three wire on the plug one red/black a black and red.I have found out today when i check with a test light on the plug thet when the dash lights work the red/black wire is the only wire that has power but when they dont work the red wire also has power. I called Honda the other day and there is a control on the back of the panel for dash light I just wondering if that could be causing the promblem.
I Hunt Goats, Rams, And Mustangs.
like you say it goes on and off right? well those wire got to a control unit, the radio and other lights in the car are supposed to dim when you turn on the head lights. behind the raido there is one wire that you normaly would conect to the raido thats of those colors you were saying red and black i think.. but it could be shorting it, just a thought
voblak2
20
May 4, 2023 02:08 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
antidote11
Dec 8, 2001 09:32 PM
