D17A9 Tuing
Old Jul 6, 2005
Albo's Avatar
Albo is an unknown quantity at this point
D17A9 Tuing
I've just bought a 02 Civic coupe with the D17A9 engine (125bhp). I'm wanting to get some more power out of the engine - beside the obvious breathing mods (induction and exhaust) that sould take it up to about 130ish, what else can I do to that this engine responds well to? 150bhp would be a nice target. I'm not rich, so big mods like turbos aren't an option - I want to keep it NA anyway.
Cheers, Al
Old Jul 6, 2005
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
^^^Replace ground wires and add a Hyper Voltage system. I would honestly do things like short shifter and work on suspension not engine. Cause you can get a lot out of tweaking our suspension, but you can spend a fortune on engine mods and make far less than 150... That's my .02
Old Jul 6, 2005
CGodwin3103's Avatar
I Am Legend
CGodwin3103 is an unknown quantity at this point
How does modding his suspension give him more power. It *might help the car jolt forward faster.. kind of as effective as motor bushing.. they help too, but not as a primary source for power gains.. then again this is OUTSIDE of i/h/e..lol.
IMO: Look at things with scrutiny.. (for example) the clubrsx.com forums have dynos for their intakes.. that a good starting place to find qaulity parts and then make a decision on price there after..
Little things like shortening the throttle cable is supposed to help.. upgraded spark plugs.. basically: If you aren't opening or smoothing out the air, then you are smoothing out how other parts perform.. when most or all things run smoothly you can beat a 'better car' since you are less prone to resistance.
Old Jul 6, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
i think to actually get 150 WHEEL hp with just "breathing" mods is impossible. it might be possible if you get dynoed on a really "loose" dyno.
I think the D17 Needs some serious internal block mods (like cams) and heavy tuning to squeeze 150 whp out of it.
Old Jul 6, 2005
I Am Legend
Pulleys, cam gears (5 bot aem is good) and cams are good improvements.
Old Jul 6, 2005
Albo's Avatar
I'm not hoping to get 150 out of breathing - I'm not a moron. I want mod suggestions APART from breathing. I have considered cams, but don't you have to sacrifice torque for power and vica-versa?
Don't get me wrong, I'm not going to spend pennies, I'm gonna put a fair bit of money into it, just not down the turbo route.
Old Jul 6, 2005
2K1Civic17"Gabe's Avatar
You would rather torque than hp. You alter the powerband. You get less power in the lowend, and more in the high end. i/h/e wont do anything for our cars. If you want some power, get the i/h/e and some nitrous. Spray a 35 shot, and that will get you some good power over stock. Only run about 800 bucks for all that as well. maybe a couple hundred more for gauges (which are needed)
Old Jul 6, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
here are some ideas. swap out a d16y8 manifold and do cam and valve springs. use an safc and have it dyno tuned. Stage 1 clutch and an aluminum flywheel is a huge difference also. Make sure you use a long tube 4-2-1 header with a high flow cat or no cat if you drop the cam in. as far as an intake goes if you get a cam use an SRI, it will accent the better top end many people here will probably disagree on this one but ive messed with intakes enough to know what works. Call Brian Crower for a recommendation on a good custom cam for what you are planning to do.
Old Jul 6, 2005
02fpcivic's Avatar
We already have a ton of torque with these motors considering comparisons to the prev sohc. Having experience with a ton of d17 mods I have found you really wont lose a ton of low end torque unless you go extreme. Such as a cam with a long *** duration.
Old Jul 6, 2005
Albo's Avatar
02fpcivic - thanks for that I will check it out.
Old Jul 6, 2005
02fpcivic's Avatar
no prob pm me if you need any questions answered. I dont know everything but maybe I can help.
Old Jul 24, 2005
Echelon04's Avatar
Don't be a ***.
Old Jul 25, 2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
i can so tell the vtecs on the ex's are not for all out power, but more like fuel ecomony quickness, giving the car more jump but at the same time using less fuel.
Old Jul 25, 2005
off topic
Old Jul 25, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
d17a9? am i the only one who caught this? wtf is it? 125 wheel horse power? someone school me
Old Jul 25, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
he meant d17a2 civic ex, and 127 brake horsepower (flywheel) about 105whp)
Old Jul 25, 2005
MajinB's Avatar
thanx
Old Jul 25, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
I/E/H- Those mods do near to nothing, especially considering how much they cost!!! Our engines come pretuned. Donot waste your money on intake, exhaust, headers, unless you wanna go with nitrous. Even then if you get the nitrous, you may not be satsified because the power is limited. So after spending all that money you could have saved it toward a swap or turbo.
Same goes with tuning the NA d17 for power, cause in the end you will need a stronger block. You could spend money on cam gears, pullys, new camshaft, ground kit, voltage kit, intake, Imanifold, headers, valve springs, safc and clutch BUT you might as well save $$$, swap k20a2, unless you love the d17, like somepeople
Definitely get the the short shifter, front upper strut bar, neuspeed is recomended, x bar, and rear sway/tie bar, comptech or other brand than progressive. Also some new dampers and bushings if you really wanna nice handleing car.
I am actually waiting for my revo ss and neuspeed upper strut bar right now, destination scan in T minus 3 hours!!!
Old Jan 12, 2008
Kenzie's Avatar
Kenzie is an unknown quantity at this point
Re: D17A9 Tuing
I have recently bought an 01 Coupe. The engine block is stamped with D17A9. So whats the difference between an A9 and a A2?
I'm located in the UK
Old Jan 12, 2008
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: D17A9 Tuing
noooo how do you know that? The UK version has a d17a2? that is new by me.
Old Jan 12, 2008
choughster's Avatar
choughster is an unknown quantity at this point
Re: D17A9 Tuing
do a search...thats the standard on all of the EX's.
Old Jan 12, 2008
ryox82's Avatar
Re: D17A9 Tuing
Well I know some overseas versions had different D17s. ::
Old Jan 12, 2008
em2.kid's Avatar
em2.kid will become famous soon enough
Re: D17A9 Tuing
I got this from Club civic but this is should clear some things up
For everyone out there wondering about all the different Civic chasis codes, here is an almost-complete list.
I would like to thank BauleyCivic for this information he posted as a response and thought it might help people if it were a lot easier to find.
(Sorry I didnt do this before... :hammer: on me)
I think it's pretty self explanitory.
4th Generation (1988-1991)
ED3 1.5L USDM All 4-door DX/LX
ED4 1.6L USDM All 4-door EX
ED6 1.5L USDM All 3-door Standard
ED7 1.6L USDM All 3-door Si
ED8 1.5L USDM All CRX standard / HF
ED9 1.6L USDM All CRX Si
EE2 1.5L USDM All Wagon
EE4 1.6L USDM All Wagon 4WD
EF1 D13B JDM All Civic ?
EF2 D15B JDM All Civic ? / CR-X
EF3 n/a JDM All Civic ? / CR-X Si (ZC DOHC)
EF6 D15B JDM All Civic ? / CR-X
EF7 n/a JDM All Civic ? / CR-X Si (ZC DOHC)
EF8 B16A JDM All Civic ? / CR-X
EF9 B16A JDM All Civic ? / CR-X
5th Generation (1992-1995)
EG1 D15B JDM All 3-door/4-door/CR-X
EG1 D15B8 USDM 1993-1995 del Sol (8-valve)
EG1 D15B7 USDM 1993-1995 del Sol S (SOHC)
EG1 D15Z1 USDM 1993-1995 del Sol VTEC-E (SOHC)
EG2 B16A JDM All 3-door/4-door/CR-X
EG2 B16A3 USDM 1994-1995 del Sol VTEC (DOHC)
EG3 D13B JDM All 3-door/4-door
EG4 D15B JDM All 3-door/4-door/CR-X
EG5 n/a JDM All ? (ZC DOHC)
EG6 B16A JDM All 3-door/4-door/CR-X
EG7 D13B JDM All 3-door/4-door
EG8 D15B JDM All 3-door/4-door/CR-X
EG8 D15B7 USDM All 4-door DX/LX
EG9 B16A JDM All 3-door/4-door/del Sol CR-X
EH1 n/a JDM All 4-door/4WD (ZC DOHC)
EH2 1.5L USDM All 3-door CX/VX/DX
EH3 D16Z6 USDM 1993-1995 3-door Si
EH6 D16Z6 USDM 1993-1995 del Sol Si (SOHC)
EH9 D16Z6 USDM All 4-door EX
EJ1 D16Z6 USDM All 2-door EX
EJ2 1.5L USDM All 2-door DX
6th Generation (1996-2000)
EG1 D15B8 USDM 1996-1997 del Sol (8-valve)
EG1 D15B7 USDM 1996-1997 del Sol S (SOHC)
EG1 D15Z1 USDM 1996-1997 del Sol VTEC-E (SOHC)
EG2 B16A2 USDM 1996-1997 del Sol VTEC (DOHC)
EJ1 D16A JDM All 2-door
EJ3 n/a JDM All 2-door / 4WD
EJ6 D16Y7 CANADA All 2-door DX/Si
EJ6 D16Y7 CANADA 2000 2-door DX-G
EJ6 D16Y7 CANADA 1996-1998 3-door CX/CX-G
EJ6 D16Y7 CANADA 1999-2000 3-door CX/DX
EJ6 D16Y7 CANADA 2000 3-door SE
EJ6 D16Y7 CANADA All 4-door LX/EX
EJ6 D16Y7 USDM All 3-door CX/DX
EJ6 D16Y7 USDM All 4-door DX/LX
EJ6 D16Y7 USDM 1999 4-door DX-V
EJ7 D16Y5 USDM All 2-door HX (VTEC-E)
EJ8 D16Y8 CANADA All 2-door EX
EJ8 D16Y8 USDM All 2-door/4-door EX
EK2 D13B JDM All 3-door/4-door
EK3 D15B JDM All 3-door/4-door
EK4 B16A JDM All 3-door/4-door
EK5 D16A JDM All 4-door 4WD/LEV
EK8 D16A JDM All 4-door 4WD/LEV
EK9 B16B JDM All 3-door Type-R
EM1 B16A2 CANADA 1999-2000 2-door SiR
EM1 B16A2 USDM 1999-2000 2-door Si
7th Generation (2001+)
EM2 1.7L USDM All 2-door DX/LX
ES1 1.7L USDM All 4-door DX/LX
??? 1.7L USDM All 2-door HX
EM2 D17A1 USDM All 2-door
ES2 D17A1 USDM All 4-door EX
EP3 K20A3 USDM 2002 3-door Si
??? K20C1 JDM All 3-door Type-R
Modified by ninety3EX at 9:50 PM 12/2/2003
Modified by ninety3EX at 9:13 PM 12/3/2003
Modified by ninety3EX at 5:19 PM 12/4/2003
Old Jan 12, 2008
speedfoos's Avatar
Re: D17A9 Tuing
Gah, I'm only familiar with the D16v1, which is a slighty more restrictive head perched on a standard D17 gut. D17A9 though.....don't know, I would imagine it's pretty much the same thing. The only differences will probably be in the transmission and head. Everything for a USDM D17 should bolt right up.
Old Jan 12, 2008
phuviano's Avatar
Slowest 7thgen in the GTA
Re: D17A9 Tuing
This thread is 2 and half years old. The OP probably doesn't even come on this site anymore, especially with the total post count.
What's up with everyone bringing up old threads lately ??
Old Jan 12, 2008
speedfoos's Avatar
Re: D17A9 Tuing
Yeah but this guy has the same engine and posted 5 hours ago.
Old Jan 12, 2008
chkolny's Avatar
chkolny will become famous soon enoughchkolny will become famous soon enough
Re: D17A9 Tuing
yea i was curious when i read A9 also, its not listed on the big long list of chassis codes either...or was it?...i really just skimmed it. lol
Old Jan 12, 2008
em2.kid's Avatar
Re: D17A9 Tuing
yea i posted a long list of chassis codes but that was because thoes are uk chassis's
Old Sep 14, 2008
tdac69's Avatar
tdac69 will become famous soon enoughtdac69 will become famous soon enough
Re: D17A9 Tuing
im in the UK and own a D17A9
Old Sep 14, 2008
Rufus's Avatar
Re: D17A9 Tuing
..and love 3 year old threads
