Bored? Clean your grounds.
Old Jun 23, 2005
MugenTak's Avatar
My car breaks and explodes for no apparent reason.
MugenTak is an unknown quantity at this point
If you're just sitting around, go out into the garage and clean the grounds on your Civic. I did this to mine, a 2001, and I could tell a big difference in the signal on the top end as well as signal to my amp. My lights do not dim anymore, at times when they normally would. All I did was take some medium grit sandpaper and work with the connections on the ground wires until they looked brand new again. I cleaned the point on the core-support where the ground wire connects with some degreaser (didn't want to sand paint off). I also sanded the battery terminals and the inside of the battery cable connetors until they too looked like new. I sanded the point at which the negative battery terminal connects to the chassis via the bracket which also supports the intake as well as the point right by the radiator hose that the ground wire is connected to. All in all, this was a good use of time. Definately worth the hour, or so that it took me. The only part of the intake system that you need to take off in order to do this, is the small pipe that runs right behind the battery. The rest of the intake system is not in the way. So get out there and clean your grounds.
Old Jun 23, 2005
2K1Civic17"Gabe's Avatar
I sanded some of mine down about 2 days ago while I had my car ripped apart. Im not sure how its doing cuz I havent driven my car yet. It should be anicer connection though, they looked like *** before.
Old Jun 23, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
just did it on my girls car, it was like snowcaps on the things
Old Jun 24, 2005
make a difference? I havent driven yet, I cant wait to feel all my new mods, and Im positive I wont notice the grounds
Old Jun 24, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Not needed if you have a 5 or more point ground kit.
Old Jun 24, 2005
I dont have a ground kit. well, the stock grounds of course, but no aftermarket yet.
Old Jun 24, 2005
mine get rusty in a month with the humidity.
Old Jun 25, 2005
civvic2k1's Avatar
civvic2k1 is an unknown quantity at this point
Dont know if this will help but electricians use what's called contact grease. This keeps the electrical connection corrosion free and maybe you wont have to clean your grounds as often.
Old Jun 25, 2005
R1Style's Avatar
If you actuall wedge a penny inbetween the battery terminal and the terminal end... the coin will collect the corrosion and not the terminals. Then just throw away the penny and put a new one in.
Old Jun 25, 2005
nice. i've tried the grease and it just washes away or gets dried up after a week.
Old Jun 25, 2005
civvic2k1's Avatar
Oh ok I guess it's just for closed enviorments.
Old Jun 25, 2005
gh0st's Avatar
TAQUITOS!!!!
too expensive.
but really, can i spray the ground points down with some wd-40 for a half-assed effort?
Old Jun 25, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
Yea its called dielectric grease. Its mainly used for spark plug boots. I have seen this before. Is this just a myth or does this really work?? An *** load of ground wires looks like its over kill. But hey weider things have been known to show results.
Dave Brabant
20
Oct 6, 2015 12:44 AM
wingsfan19
Oct 1, 2015 03:45 AM
Sep 27, 2015 11:33 AM
Bricoleur
Sep 9, 2015 12:30 PM
thaler4cuse
Sep 7, 2015 08:25 PM
