braking noise
braking noise
When I break I hear this noise like a "TOK" at the end of my braking... I change my break pads resently .. anyone has an idea what it is? its a 2001 civic btw
Drunken Master-7thgen Ninja
very true. if you changed your pads yourself take the rotors to a shop. they will machine them for you for like ten bucks each rotor. i did it for my buick. i don't have a brake lathe but i knew how to work one, so take your rotors off and go in another car and get them cut. then it should be smooth ridin.
Could be that the brake calipar is slipping and hitting something... its a common problem so your dealer should fix it for free. You know if iits this problem if it only occurs during changes in direction on the first brake.
Other than that, I seem to have this problem where that "TOK" sound comes when i push the brake past a certain point...
MamaBear2015
Jun 11, 2015 07:33 PM
anddrrey
May 11, 2015 02:30 PM
