Coolong Fans
Coolong Fans
I have 93 Civic Ex when I purchased the car it just had a new head and gasket installed. This morning on the way to work my wife said the temp went up and she cut the a/c on and the temp went back to normal. I check the fans and when you cut the air on the fan on the condenser come on right a way but I have to idle the car up to get the one over the radiator to come on and when it does it only runs for about 10 seconds after I let of the throttle. It does the same thing when the air is not on I can idle the car up and it will run as long as its idled up but as soon as I let off it stop working. I would appreciate any help I could get with this matter
Thanks
Thanks
7thgens official a$$hole
might be a bad relay, could be alot of diffrent things when t comes to cooling, if you contuinue having this problem i'd say just wire up the fan so it is always on when the car is on.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
h4ldol
Apr 24, 2017 08:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
