lighting problem
Old Jul 23, 2005
AznChinksta's Avatar
AznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really nice
lighting problem
my gages and rears lights are out, at first i was just gonna replace them but when i turn on m alarm my lights blinked cuz when i turn alarm on lights blinks 1 and turn off it blinks twice, so as i turned them on it blinks imm like WTH, i check the wiring and fuse box but nothing is wrong, some1 help me b4 the cops do plzzzzzzz.
Old Jul 23, 2005
ok now i hear a ticking noise in the fuse box in the hood *pic posted* now im getting scared, can some1 help me. I circles the fuse relay where the noise is coming from and i tested it is not the fuse. sorry if circle messed up im on laptop
Old Jul 23, 2005
heres the pic
Old Jul 23, 2005
streetglower's Avatar
well pull ou the relay that you circles and test it. Apply 12 volts to pins 3 and 4, and there should be continuity between pins 1 and 2. there should be no continuity between 1 and 2 with power removed from 3 and 4.
Old Jul 26, 2005
ok problem solved, the noise stopped, but my freakin lights are still not working
Old Jul 26, 2005
CraigW's Avatar
Have you checked the #2 fuse in the under hood box labeled "small Lights" ??
Do you here a click inside the car when quiet while turning on the parking lights ??
Old Jul 26, 2005
zen_master's Avatar
shiat....looks like the same problem on my fuse #2 and #5.....
can't turn gauge on when car turned off....
Old Jul 28, 2005
well i dun think i hear a click but ill try to listen for it. yo zen_master well mines is diffrent it wont turn on even if car is on or not and how would youu know if the fuse is blown?
Old Jul 28, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
the fuse line will be blown(that little metal wire ~ thing will be broken)
Old Jul 29, 2005
well i looked at all my fuses and all of them are fine, which fuse is the one that controls the rear lights and guages?
Old Jul 29, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
open the fuse box. the top that is now in your hand turn it upside down. look at the diagrams in there. it will let you know.
Old Jul 29, 2005
iigh thx
Old Jul 29, 2005
if you hear clicking, thats the relay.
Old Jul 29, 2005
yea i hear clicking, which relay is it the map dosent say and where can i get a replacement (if map says i cant read it its confusing) im not a real big electrical guy =D
Old Jul 29, 2005
CraigW's Avatar
The taillight relay is the one closest to the center and closest to the fuses (on the under dash box)
What year is the car and is it a coupe or sedan ??
You would need to test the relay as mentioned or check for voltage present from the switching side of it.
Old Jul 30, 2005
i have a civic 2001 LX coupe just tell me what to do ill do it.
Old Jul 30, 2005
CraigW's Avatar
Do you have access to a VOM ? (multimeter) or a 12 Volt test lamp ?
The constant 12 Volt input to the relay is on the white/green wire. (should have 12 Volts at all times)
The switched voltage out to the lamps is a red/yellow wire (should have voltage when the parking lights or headlights are on)
PM with E-Mail and I will send you the info I have, I will try to stop by the library today and print out for the 01, but this info should be correct.
EDIT: I have the schematic for the 01 wiring if you need it PM
Old Jul 30, 2005
yea i have a VOM u have a PM with my email, thx a bunch , ur my hero
Old Jul 31, 2005
i cant find the white green wire. Plus wires are all over the place cuz of the sub wire.
Old Jul 31, 2005
CraigW's Avatar
The white/green wire will be part of the wires leading to the under dash fuse box, that is where the taillight relay is.
Old Aug 1, 2005
do i have to cut the wire to test? sorry for the hassle CraigW
Old Aug 1, 2005
CraigW's Avatar
No, use the meter probe to pierce insulation. Or use a razor blade and slice off a small sliver of insulation. Cover with black tape.
Old Aug 3, 2005
YO man THX its working my fuse blew #2 and #5 if any1 has a comon problem, hit me up mayb i can guide u trough it. thx CraigW u da best
Old Aug 3, 2005
zen_master's Avatar
wait a minute, can you explain it again?
you blew #2 and #5, that's exactly the same as mine..........
what did you to to fix? i don't understand what u fixed..
in my problem........if i replace #2 and #5, my dash light indicators turned on....and i can't start my car
CarStuff
Dec 6, 2020 12:52 PM
cruisers10
May 12, 2015 10:46 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
blackbullet
Dec 1, 2001 03:44 PM
