Turn your fans on Manually
Abortion Survivor
Well lately my car has been getting hot after runs and i wanted to have a way to try and control this. I got a wiring diagram for our cars and i looked. I found out that there is a connector by the thermostat that has a green and a black wire. I would have pics where it is but i dont know how to post them p m me for pics. Ok after you find this connecter with the green and black wire all you need to do is splice a wire into the green wire and run that spliced wire to a switch. Get a good ground to the switch and there you go you now have a switch for when you want your fan on. It will still turn on automatically but now you can turn it on after runs at the track when it won't go on automatically. I hope this helps many people sorry about not having pics posted although i do have them. Let me have feedback on what you think about this good or waste of time took me about ten minutes
Touch it... He won't bite, He'll just come at you pretty quick.
I don't understand how this works... Wouldn't that just be cutting the power to the fan? Wouldn't it stop working when the switch isn't turned on?
I Hunt Goats, Rams, And Mustangs.
Thats cool.. not a bad idea but you could try getting a different thermostat, like mugen or spoon.. something that opens up at a lower temp.... and a new radiator should help.. since your boosted.. im assuming.
Abortion Survivor
Yeah well i just wanted to see how this worked i have yet to find a thermostat for our cars i even tried fitting a jackson racing thermostat for an older civic but failed because they were different i am planning on buying a Koyo
yeah.. humm i had found some at one point, but now i got a DC5R and its eaiser to find those parts so i deleted most of my D17 pages.. i forget where.. ill have to look it up.. but let me know how that fan thing works. take some pic's if you can.
Abortion Survivor
I have pics don't know how to post you just splice a wire into the green wire that is where the thermostat is. Then you run it to a switch add a ground to the switch and when you hit the switch it turns on the fans
7thgen Power Maker
Abortion Survivor
Originally Posted by _Viper_
Just remember to shut it off when you get out of the car or you will drain your battery ....
duder
15
Jun 11, 2015 04:28 PM
Lunar
May 22, 2015 07:43 AM
Pir8pete
165
Mar 6, 2009 05:16 PM
