A/C making car idle low?
Old Aug 1, 2005
noakail's Avatar
noakail is an unknown quantity at this point
My ac was broken in my '03 civic and just fixed it but now i run the ac and the RPMS are below 1000 but when its off it idles just above 1000. the car also jerks at random when not shifting. is this normal?
Old Aug 1, 2005
Bires's Avatar
Bires is an unknown quantity at this point
No to both things. Your AC should drop your idle, then it should come right back up. The jerk thing...that sounds bad, maybe your clutch is slipping?
Old Aug 1, 2005
Ichiban's Avatar
Ichiban is an unknown quantity at this point
My car does that too sometimes when I just start it. I know it's not my clutch because I have a Clutchmasters FX100 clutch. Acually it does that sometimes when the AC isn't on. But only when I drive it right after a cold start.
Old Aug 2, 2005
noakail's Avatar
Ill turn it in this week and find out. what if the idle stays below 1000 and does not come back up?
Old Aug 2, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
my car normally idles below 1000 a few minutes after startup and stays there.
Old Aug 2, 2005
Two problems. 1. stock idle without load is 700+/-50rpms. 2. Using the a/c should usually raise idle by 100rpms when its on.
Old Aug 2, 2005
Jrfish007's Avatar
Exactly, you shouldn't be idling that hgih to start. And when you turn on the AC the computer should sence a load and increase the RPM about 100 RPM, which should still be below 1000RPMS.
bsmiley
Apr 27, 2015 01:27 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
tattedlariat
Apr 20, 2015 09:26 PM
dooner24
Apr 14, 2015 07:51 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
