A Pop, and wierd first gear? Help!?
Old Jul 21, 2005
Whelan's Avatar
Whelan is an unknown quantity at this point
Ok so when i accelerate every now and then there is a slight almost pop or click noise from the front right of the car. It happens to on occasion when I let off the gas.
But that is not my biggest issue.
Recently in the last week my first gear is all fawcked up. I start and when I punch it and get 1st gear up above 4500 the car bogs right around 5, then it launches forward. It almost feels like the VTec cant decide to kick in or not and when it does it hits really hard.
It only happens on occasion but lately its been happening more and more, any ideas?
Old Jul 21, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
Is this an auto or 5spd?
Old Jul 21, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
the Vtec kicks in at 2500rpms if ur at full throttle and 3k any other time so I wouldnt think that would b the problem
Old Jul 21, 2005
Whelan's Avatar
5 speed.
I was only about 1k over my oil change and I called Honda the tech said that my VTec kicks in around 4-4500.
The reason i put this in is because i was on the highway and all of a sudden it shut off, then once it went under 4k it came back to life and drove fine. I brought it to my guy and the oil stick was dry! No leaks or smoke he said it could be a mix between heat and the fact that all cars use some oil to a degree cause its a liquid. I trust this guy very much, good work and quality. So he changed the oil and it is fine now. But my engine light is still on. I guess I should disconnect the battery to see if that gets rid of it.
Old Jul 21, 2005
ragingSPAM's Avatar
I just burnt my tongue
if there was no oil on the stick maybe u got soem kind of blockage in the system and your oil pump pickup is not gettin any oil so its screwin up even tho there is oil in the pan
BryanM.
Aug 29, 2015 03:26 PM
WaryDriver
Aug 16, 2015 11:22 AM
JetsterDajet
Aug 15, 2015 08:07 AM
Bonnabell
Aug 14, 2015 04:15 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
