Window Switch for Nitrous
Old Dec 20, 2002
Flash6009's Avatar
Flash6009 is an unknown quantity at this point
I have a really simple queston, I have read all the post on this topic.
I have read spraying in first is bad, for the fact that you can redline and hit the rev limiter in less then 2 seconds. But what if I set my Window Switch from 4000-6500rpm will that be ok, so that way after it sprays it cut-offs and then I shift. So that way I'm not going to mess up and redline and hit rev limiter BOOOOOM!
Thanks for all the intelligent answer[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 20, 2002
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
that will be fine, as long as you set the switch to cut the nitrous before the rev limiter....use nitrous in first if you learn how to launch with it.
Old Dec 24, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
i ran into a problem when trying to instal mine, I could not get it to work and I called msd, they said the window switch is not compatible with our car yet- msd is working on it. BTW, NX and NOS both get their window switch from msd and put there own stickers on them, they wont work either. Msd said they should have a solution around springtime.
PS- If you figure a way to rig it to work, the hell with msd, post how you did it!!!!!
Old Dec 25, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
get a HKS FCD: Fuel Cut Defender
Old Jan 3, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
hittin the rev limiter is not that bad[IMG]i/expressions/demon.gif[/IMG]
Old Jan 12, 2003
spooner's Avatar
spooner is an unknown quantity at this point
i feel really noobish for asking this as i should but do automatics have a rev limiter, or is the sometimes that you should not spray
Old Jan 12, 2003
chefjnr's Avatar
dont spray, not worth it for a autmatic, a lot more expensive to rebuild a automatic tranny- for manual civics you need to upgrade the clutch because N20 burns out the stock one so fast- just something to think about
Old Jan 16, 2003
supercivic's Avatar
supercivic is an unknown quantity at this point
Quote
[hr]Originally posted by: spooner
i feel really noobish for asking this as i should but do automatics have a rev limiter, or is the sometimes that you should not spray[hr]
go ahead and spray the house down. If your tranny goes, then dont bother rebuilding it, just go for the manual swap.
Old Jan 16, 2003
Baghead's Avatar
Baghead is an unknown quantity at this point
is there a window switch that works with ours cars that is out on the market?
Old Jan 17, 2003
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
trying calling a few company's and find out.They are not car specific.
Old Jan 21, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
Quote
[hr]Originally posted by: chefjnr
dont spray, not worth it for a autmatic, a lot more expensive to rebuild a automatic tranny- for manual civics you need to upgrade the clutch because N20 burns out the stock one so fast- just something to think about[hr]
What are you talking about its so much better just think you are starting out in a gear and you dont use it till you are above 3000rpms and then you dont have to shirt so its not killing your gears
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
cukaracha
Jul 17, 2015 05:48 PM
Jul 14, 2015 03:39 PM
1khilari
Jul 9, 2015 08:12 PM
ballmich
Jul 9, 2015 11:59 AM
