Help! removing seats...
Old Dec 18, 2002
vistec's Avatar
vistec is an unknown quantity at this point
I am removing my front seats, and I am having problems removing the yellow srs plug. The grey one is easy, it has the little tab you push and it comes out. The yellow plug has no tab, do I just pull it out or is there a lock/tab I am not seeing???[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 19, 2002
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
if you have an ex i suggest not to take those off, because they control your side airbags, now if you have an lx, or anything else go right ahead, the yellow tab, just comes right off, it would be easier to actually remove the bracket from the seat so you can get a better look at the plug, but i cant remember how i got mine off, i just did easily, but i promise you wont break anything as long as you dont use brute force, ill check it tomorrow and see, later
eric
Old Dec 19, 2002
vistec's Avatar
i have an ex but no side airbags. I tried to just pull it out but it feels like it is locked in there. I dont see any tabs to push to unlock it.
Old Dec 19, 2002
666's Avatar
666
666 is an unknown quantity at this point
Its a pain in the *** to remove but when its unplugged DON'T start the car or put the key to the accesory position. I did that with my seat unplugged and the SRS light went on and you have to get it reset at the dealer. Or just disconnect the battery, then it won't light up.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 19, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
Is it anything like the power window switch plug?
If you don't know what those are like, I think that it might be like those...those you have to squeeze as close to the part where it plugs into as you can.....so like don't squeeze the outside end that you can grab easily....squeeze the inside end of the plug, as close to the end of the connector as you can, and then try to pull it out....hope that helps!
EDIT: I attached a pic.....hopefully it helps lol because everything i said in here might be confusing hahah ....even the picture might be but hey i tired[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Yah so squeeze the end that is circled in red....
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] plug.jpg (5 Kb)
Old Dec 21, 2002
vistec's Avatar
666 how did you remove it???
Old Jan 27, 2003
vistec's Avatar
anyone else any any suggestions???
Old Feb 18, 2003
vistec's Avatar
i cant get this thing out...[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Feb 18, 2003
LC's Avatar
LC
LC is an unknown quantity at this point
Im thinking about taking my car to the 1st annual honda meet at Englishtown and I would also like to take out my seats. I dont want to take out my front seats because of the SRS , but I do want to take out the back seats. Do you guys think its worth it? Also does anyone have a DIY to remove the seats on the back?
Old Feb 18, 2003
cdmx's Avatar
i think it takes two hands you take the left hand and push half the plug together and pull the back out with the other hand
...thats my best explanation
Damn HeadGasket
Aug 23, 2015 05:27 PM
herbiej
22
Aug 23, 2015 01:02 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ballmich
Jul 9, 2015 11:59 AM
