Apex VAFC diagram
Apex VAFC diagram
just found this on apex's website, is this for real?
http://www.apexi-usa.com/productdocu...ivicEXVAFC.pdf
Hail to the king baby
Quote
[hr]Originally posted by: Hwoody77
Yes, I actually just wired it up yesterday, and I"m about to test it out right now. Brb[IMG]i/expressions/face-icon-small-smile.gif[/IMG].[hr]
Quote
thanks a lot man!
Quote
Yea, the VTEC portion does work, the VTEC is SICK! I will be posting videos in the next few days...[hr]
thx!
Its a celebration bitches!
i just installed my apexi V-AFC and i love it, when i set the V-tec at 4900 rpm, it kicks in nasty, kinda like if i had nos or something...
i don't know but there is a problem, the check engine light goes on sometimes, and is off at other times... i don't know why...
im going back to the place i had it install, other than the little light, it run normal and perfect... i also love the gauges, graphs, and meters.... it is so sick, its like me being able to reprogram the fuel, whenever i want to...
Quote
[hr]Originally posted by: HondaLuver
im going back to the place i had it install, other than the little light, it run normal and perfect... i also love the gauges, graphs, and meters.... it is so sick, its like me being able to reprogram the fuel, whenever i want to...[hr]
show the people that installed it for you the new diagram on apexi's site. maybe they had it different?
if you have the stock ecu, you can only adjust the air/fuel ratio off from stock settings by like 1%, or by a very small amount. same with vtec controller. why did you set the vtec to engage at 4900k? it engages at like around 4300-4700k stock.... so maybe that could be it, try turning it back down a little and see, same goes for you air/fuel settings too, turn those back closer to stock, and see if it still does it. if it doesn't then go ahead and tune from there until your at the threshold of max performance and no engine light.
hope that helps.
hope that helps.
rman1900
21
Sep 10, 2018 04:52 PM
EM2661
Sep 11, 2015 06:01 PM
horta1212
Aug 22, 2015 08:31 PM
ek_rebuild
Aug 11, 2015 08:00 AM
sch2cm
Jul 21, 2015 09:58 PM
