VTEC Head Swap
Old Dec 11, 2002
SqueezeBoy's Avatar
SqueezeBoy is an unknown quantity at this point
VTEC Head Swap
What will I need?
-vtec head
-EX ECU?
Anything else?
Thanks, any input would be greatly appreciated.
Carl
Old Dec 11, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
dont waste your money!!!!!!!!!!!!!!!!!!!!!
with all the money you will spend you could do some REAL engine work to your civic , plus if you do it you will regret it soooo much when you find out your 1/4 mile is the same
Old Dec 12, 2002
Roy's Avatar
Roy
Roy is an unknown quantity at this point
i think you would have oiling issues.
Old Dec 12, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Quote
[hr]Originally posted by: sadboy916
with all the money you will spend you could do some REAL engine work to your civic , plus if you do it you will regret it soooo much when you find out your 1/4 mile is the same[hr]
I agree. There's nothing spectacular about the EX that makes it innovative. EX VTEC sucks anyway. The Civic is the worse example of a real VTEC and you'll just be disappointed in the end. You'd be better off putting your money into the forced induction and taking advantage of the lower compression ratio in a DX/LX engine. I'd rather encourage you put your money into some internal engine work and a REAL ECU upgrade. Don't think just because the engine doesn't have a VTEC in it means it's crap, it's an engine... and any engine can perform better than it normally does. Just do with what you have. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 12, 2002
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
why would you have oiling problems? the block is the same, the headgasket should be the same...I doubt honda made very different parts between the 2 engines. I'm going to try the swap if I find the parts cheap enough....I'm sick of the don't do it posts just answer the guys question if you don't know leave it alone....as far as I can see you'll need the head,manifolds, vtec solenoid etc and the computer...
Old Dec 12, 2002
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
i've heard that you need the ex transmission too, but i don't really believe that....if you haven't already searched i would suggest you do so, there have been many posts about this
Old Dec 12, 2002
SqueezeBoy's Avatar
Thanks for all your ideas. PlatCruiser, we both live in the phoenix area so possibly we can get together and make a list of all that would be needed.
Carl
Old Dec 12, 2002
yositoco's Avatar
yositoco is an unknown quantity at this point
First of all you should ask yourself what do you want from youre engine... If you want 10 to 15 more horses the vtec head is a good idea... If you want more than 30 horses you should try to save for forced induction... If you are an all motor junky buy the head and wait for some pistons and a cam to come out.
In my case I got lucky and bought and found a VTEC head on ebay and bought it for 150 and Im going to install it during the hollidays,
things I will need fos the swap:
1- VTEC head
2- RPM switch
Before any of you start replying that i will need this and that let me explain.
The VTEC comes with the solenoid, so you dont need a solenoid since you already have one. The VTEC computer and the non VTEC computer are the almost identical. Up to what I know the only difference is that the VTEC computer activates the VTEC. This is why i will need an RPM switch, to activate the VTEC "manually". With respect of the manifolds, the intake manifold is the same and the exhaust manifold (header) bolts on. The only problem i could see here would be if the porition of the manifold was different and the exhaust wouldnt line. Nothing a muffler shop couldnt fix.
In conclucion if you find a cheap head buy it!!!
p.s. Im going to dyno my car before and after the swap.
Old Dec 13, 2002
good post...I have a V-AFC laying around.....reason why I would think you would need the EX computer is doesn't the map sensor (dunna know which yet) switch fuel tables to add more fuel with the air coming in on the vtec transition. hell if it comes down to it I'll just install the V-AFC on this car and buy a S-AFC for mine...I can tune the AF on the dyno so I shouldn't have a problem .I don't think you need a ex tranny since I'm using the LX block and the tranny is already bolted to it [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 13, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
The oil problems that he is refering to are related to the lack of an Pre-drilled VTec Oil Line. i believe the with any HYBRID engine, i.e., Vtec head mounted to a NON-Vtec Block, you will need to drill a Vtec Oil line into the block, as NON VTEC blocks are not equipped with this oil line. regardless of whether its DOHC or SOHC or its year, i am pretty sure that it is a must, and therefore you will need to do it too. id definitely do you research on this one. as for cost efficiency... well, for $150, thats not a bad price for a SOHC Vtec head, however you will never see drastic improvements or advantages from this swap due to the lack of potential in these SOHC motors. obviously you can build them up to be ALL MOTOR or Forced Induction, but thats the limit with them, and you will still barely be able to hang with a Stock RSX Type-S.
Old Dec 13, 2002
I'll have to check the ole FSM out on this...anyone have pics of the deck of each block?
Old Dec 15, 2002
Mitch's Avatar
Mitch is an unknown quantity at this point
The "EX" pistons have a higher compression hieght. You could buy some over sized factory pistons to get your compression up. As for the ECU the vtec activation also has more advanced timming, air/fuel maps, and a knock sensor to constantly advance/retard timming.
Old Dec 15, 2002
instead pistons I could just shave the head from more compression
Old Dec 17, 2002
paolo's Avatar
paolo is an unknown quantity at this point
I would just save the money that you would spend and buy myself a new car. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Although trickin a smaller car into something unimaginable would feel a lot better
rather than having a car with all the power.
dbagaus
SOHC D17Ax non-VTEC - VTEC Engine Swaps
70
Feb 22, 2023 04:26 PM
tadr88
Jun 8, 2015 12:28 AM
01civyv3
Jun 2, 2015 05:21 AM
MiniMi
May 27, 2015 01:57 PM
Dakker
Jan 21, 2002 12:55 PM
