rear upper strut install
ok i have two of the four bolts off, i cant get the other two
they own me, the wrench i have i cant get enough tourque and i cant get my socket wrench to fit over the screws
any suggestions for removal
Quote
[hr]Originally posted by: ironcow
i hope i dont strip the bolt, that would suck *****[hr]
you can use anything that will fit over your wrench for a breaker bar...(ie. a pipe) just put it over the wrench and it makes it an extension, giving you more leverage. You wont strip the bolt if you use a 14mm socket/wrench...should fit perfectly.
Good luck.
FYI: i had to dremel out some of the metal to get mine to sit flat...Might want to check that before you install it.
Edit: I was talking about the metal on the floor of the trunk.
Good luck.
i used half drive craftsman whenI took mine off I dont knwo if I would recomend using a breaker bar. If there that tight which they should not be (35 ft lbs. is spec) than a breaker bar would be bad because you might just twist the bolt right off the strut that would be worse than rounding the nut out be carefrul you a GM's heat valve penetrate that is some incredible stuff when it comes to breaking bolts loose
bryden13
May 18, 2015 12:22 PM
