Installing rear lower tie bar.....HELP!!
Old Dec 2, 2002
sumama's Avatar
sumama is an unknown quantity at this point
If I remove the bolts for the lower tie bar installation, what will happen? Will everything stay together? It seems like the bolts are holding everything together, and if I take it off, some parts will fall off. Will they? or are they just nuts? thanks for your help.
Old Dec 2, 2002
Guest
Guest
Posts: n/a
when u take the bolts out everything will stay.. they did on mine
Old Dec 2, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I did this:
Old Dec 2, 2002
Guest
Guest
Posts: n/a
yea i would feel more safe doing that.. i was scared $hitless when i was diong mine
Old Dec 2, 2002
sumama's Avatar
Whew, thanks mex. I was under their without a jack and i was just about to take it out. The car coulda just fell on me! if that thing fell apart. i guess installing a tie bar is harder than i thought.
Old Dec 3, 2002
speed werx's Avatar
speed werx is an unknown quantity at this point
the wood thing was my idea i handed down to help out after i found out its a bitch to line ht bolts up again... well do it for sure...i actuall stacked boards... so it was sturdier, but hte wedge works too [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 3, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
I used a hydralic jack to jack my car up and my oem jack to hold up the control arm
Old Dec 3, 2002
SkiLLzSter's Avatar
illest ma f*cken member
to make it even easier use a vise grip to clamp the control arm so it won't fall down...then remove the bolt
Old Dec 3, 2002
sumama's Avatar
what is the control arm??
Old Dec 3, 2002
sumama's Avatar
ok, thanks Mex AND hondawerx.com for the info. Do you guys remember how many inches the piece of wood was that's holding everything up? thanks
Old Dec 3, 2002
CapYoda's Avatar
Escaped Convict
oh man. heh.
the lower control arms are those two things comming outta each side.. holding onto by those two bolts u were trying to remove without a jack... the car would have fell on you.
good thing u came and ask eh? heh.
u can do the wood thing, or simply insert another bolt from the rear to keep the LCA from dangling around... its kinda a hassle to adjust it into place once it falls outta place.
that idea is from Grey. pretty straight foward... as u take the bolt out, insert one in temporary... I think u get what I'm talking about... a bolt, a stick, anything that'll hold.
I'm having a lower tie bar on my way too.... been waiting for the neuspeed one forever, so I just went ahead and got the ebay one for now.
Old Dec 3, 2002
Mex's Avatar
Mex
you don't really need to jack up the car to install a lower tie bar. I only did it for more room. it doesn't matter if the lower control arm falls when you're installing it, but if it does it'll take you a very long time to wedge back into place and put the bolt through.
Old Dec 4, 2002
sumama's Avatar
Quote
[hr]Originally posted by: CapYoda
oh man. heh.
.[hr]
Quote
[hr]Originally posted by: Mex
you don't really need to jack up the car to install a lower tie bar. I only did it for more room. it doesn't matter if the lower control arm falls when you're installing it, but if it does it'll take you a very long time to wedge back into place and put the bolt through.[hr]
Ok I am very confused here. If I just take off the bolt without jacking up the car, will it still be safe under there? Is the whole purpose of the wood thing to just keep everything in place?
Old Dec 4, 2002
Mex's Avatar
Mex
Quote
[hr]Originally posted by: sumama
Ok I am very confused here. If I just take off the bolt without jacking up the car, will it still be safe under there? Is the whole purpose of the wood thing to just keep everything in place?[hr]
I didn't even notice CapYoda's post until now. maybe he knows something that I don't, but looking at the situation using my own logic, I think-- what's it matter whether the car is being supported by the rear springs or a jack? both would be supporting the body, just in a different location. if the control arm falls, it falls. the control arm itself doesn't hold anything in place when the vehicle is just sitting there...
if you have enough room under the car to work without lifting it, it's safe the wood this is solely to prevent the control arm from falling out of alignment.
Old Dec 4, 2002
CapYoda's Avatar
Escaped Convict
HAHAHA.
man I'm a dumb****
I forgot about the springs and the shocks holding it up. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
even then, it should be obvious the control arm doesn't hold the car up...heh. I must have been on something.
anyhow dont listen to me, its obvious I dont know anything [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 4, 2002
sumama's Avatar
Thanks guys. Appreciate your help.
Old Dec 5, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
I just used the jack and pushed up the brake outward so the holes would be even. No need for any extra creativity. You only have to do this on one side.
rtachs
Jul 16, 2015 05:32 PM
tomg
May 21, 2015 07:05 AM
jdawgzcivic
May 20, 2015 08:14 PM
El_Spic
Apr 23, 2015 03:14 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
