Motor Swap Question...
Old Dec 16, 2002
M1kEzPr1NcEzZ
Guest
Posts: n/a
Hey does anyone know if the old b16a2 from the 99-00 Si will swap correctly into the new 7th Gens? I know people tell me just to swap the k20 but...price is lot diff...I mean a b16 with tranny might run you like 2-4K with swap, so let me know if motor mounts fit etc..or would it need lots of work...also...does anyone know if it is possible to just put the DOHC Head onto the EX block d17? kinda like an LS VTEC deal...? b.c. I heard the d17 is pretty strong block just not all that great in performance let me know a good way to get great hp for cheap besides turbo etc....
Old Dec 16, 2002
S2000man01's Avatar
O RLY
Youre going to need just as much work, if not more, for a B16 swap.
Not to mention the fact that it's illegal, and no shop will probably do it anyways. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Moved to tech talk....
Old Dec 16, 2002
speed werx's Avatar
speed werx is an unknown quantity at this point
No you sanrt swap heads.. a LS motor was DOHC to start with.... B16 should fit fairly easy...but still need lots of mod work. and it will not pass emisions.
Old Dec 16, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
a) it's illegal to put an engine that is older than the car into that car. you can only swap an engine that is newer than the chassis
b) the b engines are not drop in swaps for the 7th gen civic, so it would take MORE work than the K20 for custom mount work, and you'd end up paying about the same amount of money for an older, weaker engine
c) you can only swap heads that are common to the series of engine (B to B, D to D, K to K, etc.) and sometimes not even then. therefore, you can't put the DOHC B head onto the SOHC D block. you can only swap the DOHC VTEC head onto an LS cause it was a B engine to begin with.
d) the best way to get a lot of HP for "cheap" would be a nitrous system - 50 shot for around $700, or $2000 with all the bells and whistles. a turbo for the 7th gen would have to be custom, so once again you're looking at major money, 4-5 g's, maybe more. i guess the money all comes down to what you can afford though.
Old Dec 16, 2002
FroggyLx's Avatar
FroggyLx is an unknown quantity at this point
[QUOTE]Quote
[hr]Originally posted by: AFlyer
There's some places in the US where its not illegal or where they just don't check (like in my case) and if someone has an extra b-series motor lying around maybe it's not such a bad idea. Wasn't some guy trying to do this awhile back? From Japan or something??
But as for the question your probably going to have to get mounts made for it, probably some axles too, not to mention converting to a returnline system and all the wiring/ecu stuff. It's probably a lil more complicated then that but we'll never know unless someone tries it.
Old Dec 17, 2002
dragoon's Avatar
just remember HAsport has the mount kit out for the k20. makes it much easier
Old Dec 17, 2002
S2000man01's Avatar
O RLY
[QUOTE]Quote
[hr]Originally posted by: FroggyLx
Quote
But as for the question your probably going to have to get mounts made for it, probably some axles too, not to mention converting to a returnline system and all the wiring/ecu stuff. It's probably a lil more complicated then that but we'll never know unless someone tries it.[hr]
I do believe that's a federal law.... meaning it's illegal everywhere. It has to do with crash regulations and emissions control.
mistermenphis22
Jul 13, 2015 04:43 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
fatih717171
Jul 8, 2015 12:14 AM
prototype
Feb 6, 2002 05:40 PM
