Easiest way to remove rear H?
Old 12-21-2002
CivicPunker17's Avatar
CivicPunker17 is an unknown quantity at this point
I'm gonna remove my rear H emblem and replace it with the beetle "turbo" badge. What's the easiest way to remove it because I know there's those two prongs that hold it in too. Do I just heat it like the others then pry it off? I don't feel like putting a scratch on my trunk.
CivicPunker17 is offline
Old 12-21-2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
if I remember correctly, i think if you open your trunk, you can push the two prongs out from the inside of the trunk lid
01civicboi is offline
Old 12-21-2002
CarbonFly's Avatar
I think that there are 2 white caps on the back that you pop off then it pulls right out.
CarbonFly is offline
Old 12-21-2002
WHTRIC's Avatar
WHTRIC is an unknown quantity at this point
Real easy.
1) place thick tape i.e. black tape along the bottom edge and top edge of the H
2) With a thin small blade screwdriver or better yet a plactic razor blade pry up on the bottom edge and top edge
3) Get finger under bottom and or top edge of H and very easy pull off.
Note: there is automotive adheisvie tape on the top edge of the H only.
There are two holes in the trunk lid that the white clips fit in and the H pushes in to these. If you try to push out from the inside of the trunk you will bend the trunk lid. (very bad) the white clips will not come out with the H. Good luck and happy moding.
WHTRIC is offline
Old 12-21-2002
amhtown01's Avatar
dental floss...
amhtown01 is offline
Old 12-21-2002
LEVA
KeNsHiN's Avatar
Quote
[hr]Originally posted by: amhtown01
dental floss...[hr]
i heard that this is one of the easiest way of taking that off
KeNsHiN is offline
Old 12-21-2002
Roadog's Avatar
Roadog is an unknown quantity at this point
Grab it and pull (the emblem) it worked for me!
Roadog is offline
Old 12-21-2002
RedDragon333's Avatar
Quote
[hr]Originally posted by: CivicPunker17
I'm gonna remove my rear H emblem and replace it with the beetle "turbo" badge. What's the easiest way to remove it because I know there's those two prongs that hold it in too. Do I just heat it like the others then pry it off? I don't feel like putting a scratch on my trunk.[hr]
I WANT A TURBO
RedDragon333 is offline
Old 12-21-2002
dspirit79's Avatar
dspirit79 is an unknown quantity at this point
Me Too!!! <SIGH> Gotta start saving more... [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
dspirit79 is offline
Old 12-23-2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Quote
[hr]Originally posted by: WHTRIC
Real easy.
There are two holes in the trunk lid that the white clips fit in and the H pushes in to these. If you try to push out from the inside of the trunk you will bend the trunk lid. (very bad) the white clips will not come out with the H. Good luck and happy moding.[hr]
Not true. All you have to do is use some needlenose pliers and squeeze the white prongs on the inside of the trunk. They are made of soft plastic and they'll come out of the holes easily.
-Kre
Krepoort is offline
mohawkboom
67
08-25-2015 12:28 AM
alex_nyc
06-18-2015 11:45 AM
Flipg123
05-22-2015 10:43 PM
Civicchik01
12-07-2001 06:33 PM
Quick Reply: Easiest way to remove rear H?
