How do you remove the Ebrake cable
Old May 17, 2015
Flipg123's Avatar
Flipg123 is an unknown quantity at this point
I am replacing one of my rear calipers, and can't seem to figure out the right way to remove the ebrake cable. I know that I can remove the 2 bolts that hold the bracket in place, but I have already messed one of the bolt heads up, so I would have to cut the bolt to get the bracket off.
It looks like I should be able to remove the U shaped clip and the cable should slide through the hole, but I don't think that the hole is big enough for the cable to slide through.
Old May 17, 2015
Re: How do you remove the Ebrake cable
Why you did not try this already? It's made that way for a reason.
It will go if there is enough slack in the cable,
Old May 22, 2015
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
Replace the damage bolt, grab the cable tightly with some needle nose vice grips, the pull the cable forward up or down and it will fit through. I can't remember which but try this I remember it was a little tricky. Watch the clearance as you move it and you will figure it out.
greenbackz
Jul 30, 2015 12:04 AM
Dani1993
Jul 24, 2015 09:02 AM
Dave1984
Jul 22, 2015 06:10 PM
muttleytm
Jul 11, 2015 06:00 PM
ballmich
Jul 9, 2015 11:59 AM
