I just bought a Lower Rear Tie Bar, i need some help on exactly how to install?
Old Dec 17, 2002
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
I havent tried yet, so maybe its not as hard as i think it is, but im not sure on how to even begin doing this?
does the tie bar itself have to be all tightened up, or do you tighten the bolts on it only after its been installed some help would be appreciated thanks guys [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
dave[IMG]i/expressions/beer_yum.gif[/IMG]
Old Dec 18, 2002
CelCUs's Avatar
CelCUs is an unknown quantity at this point
I'm doing mine right now and am now having problems because i rushed it a lil'. Do a search there's a ton of info, pay close attention to the posts about using wooden blocks or clamping the metal together. . . the info's on the site. . . just take your time and figure out exactly how you're going to approach the install.
Old Dec 18, 2002
pt's Avatar
pt
pt is an unknown quantity at this point
i did mine it was a snap i used one jack in the middle of the wheel base and used the other for arms for the back tire to raise it a lil to un screw the bolt it took off some tension i hope this helped a lil bit feel free to pm if you need help
Old Dec 18, 2002
Snakes's Avatar
Snakes is an unknown quantity at this point
here's a little tip for how to keep the holes alligned when you remove the bolts.
tie-bar installation tip
Old Dec 18, 2002
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Quote
[hr]Originally posted by: slammed2k2
dave[IMG]i/expressions/beer_yum.gif[/IMG][hr]
My lower tie bar was very easy to install.
1. Jack up rear side like normal and remove the tire.
2. with a socket wrench remove the bolt.
3. the hole stayed lined up some, I used a mallot to
hammer it back some to line up.
4. put the bolt through the bracket and re-tighten.
5., put tire back on and lower car.
6. repeat steps 1-4 for the other side.
7. intall lower tie bar and tighten everything up.
9. repeat step 5.
Takes no longer then 20 minutes.
Very easy install
mistermenphis22
Apr 3, 2016 08:06 AM
jdawgzcivic
May 20, 2015 08:14 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
CapYoda
Nov 11, 2001 05:17 PM
