Ractive Coilovers
Old Nov 28, 2002
hondamatic18's Avatar
hondamatic18 is an unknown quantity at this point
Ractive Coilovers
can someone tell me if they have ractive coilovers or if they know anyone with ractive coilovers, are they a good buy or are they just garbage and why shouldn't i buy them? i am hearing mixed things and i want to get coils so what kind should i get...are the ractive ok?
Old Nov 28, 2002
CarbonFly's Avatar
First post huh? Welcome to 7thgen!!!!!!!!
Sleeved coilovers in general suck.
Get true Coilovers like Tein SS or B&G. Then you would be rockin'!!!
Old Nov 28, 2002
SatinSilver2k1's Avatar
SatinSilver2k1 is an unknown quantity at this point
what are sleeved coilovers..explain please
Old Nov 28, 2002
how much would those coils go for in canada tho? uh and what is wrong with sleeved coils?
Old Nov 28, 2002
CarbonFly's Avatar
To explain this you need to understand what a coilover is..........
A coilover suspension is simply one that has the shock body located within the space inside the coil spring (as installed on the car). This is the best design possible because the shock is moving in the same plane as the spring, which ensures that it can most accurately control spring movement, plus it's usually the lightest. In our double wishbone suspension systems, the shock's only job is to control spring movement, so it makes sense that Honda equips all of their performance cars with coilover systems.
The popular catch phrase "coilover" is only applied to systems that are sold complete with both shocks & springs (and sometimes upper mounts), but the truth is that every spring or shock you install on the car will function in a coilover system. Here's the basic breakdown as far as you are concerned: Honda uses almost exclusively the coilover setup on their current cars.
Aftermarket spring manufacturers like Ractive simply one-up their design by adding height adjustability to the system. This comes in the form of threaded shock bodies and adjustable spring perches, we generally refer to them as "sleeved springs". There are also shock manufacturers like Koni who one-up Honda in the shock absorber department by offering adjustable shocks, which are adjusted usually by a **** somewhere on the shock body or rod.
Then at the top shelf of coilover designs, you have companies like Tein who one-up everybody else by offering a complete & ready to install coilover package that is adjustable in several different ways (height adjust, rebound adjust, compression adjust, whatever they throw in) and comes as a properly matched system. These are the systems we refer to as "true" or "complete" coilovers. Usually these shocks are rebuildable and offer custom valving options, and the company usually has a variety of spring rates available for you. If these are the best systems, it's simply because they are the most complete.
The only system that offers a better garaunteed match between spring & shock are usually the stock units (which of course are not stiff enough and have no adjustability). What I am getting at here is that just because you get springs from one manufacturer and shocks from another does not mean that you won't have a kickass ride, it just means that there is more possiblity of mismatching one part to another. As we have pointed out many times, the simple Eibach Pro Kit & Koni adj. shocks combo seems to whoop *** on many other street setups without costing an arm and a leg (relatively speaking).
Wheeeeew........that was a lot of typing
Old Nov 28, 2002
oh cool thanks man....uh so i think i pretty much got everything you were saying i'm gonna look into the higher end coils like koni and stuff you were suggesting but what your really getting at though is that it wouldn't matter if i get the ractive then...the car would not be hurt by them...it would just well i guess not perform as well as it could....right..?
Old Nov 28, 2002
CarbonFly's Avatar
Just sleeved coilovers can for for around $200 USD.
True Coilovers like Tein SS for for $1200 USD.
Much more expensive i know.......but you get what you pay for. Even if you did get the Craptive...oops, I mean Ractive you should also get aftermarket Shocks. That would cost you around $550 USD.
If you do get Sleeved ones, I suggest Ground Control over Ractive.
Old Nov 28, 2002
cambo's Avatar
I wish I was asian
my god......flyriceracer02 actually sounds like he knows his stuff. simply a m a z i n g ! ![IMG]i/expressions/demon.gif[/IMG]
Old Nov 28, 2002
CarbonFly's Avatar
Quote
[hr]Originally posted by: cambo
my god......flyriceracer02 actually sounds like he knows his stuff. simply a m a z i n g ! ![IMG]i/expressions/demon.gif[/IMG][hr]
Was there any doubt?
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Nov 28, 2002
hah ya man you do know your stuff he's right! uh thanks a lot well i'm gonna look into all this before i actually get anything because i still have until spring to do it but thanks for all the tips i'm sure they'll come in handy once i get my coils!! thanks bud!
Old Nov 28, 2002
RedDragon333's Avatar
Get the true coilovers. Its the only way to ride. Im saving for the Tiens!!!
and good job
FlyRiceRacer02
Old Nov 28, 2002
rackness's Avatar
rackness is an unknown quantity at this point
so what isa sleeved coilover again?
j/k great post it cleared up some questions i had as well thanks
Old Nov 29, 2002
KeNsHiN's Avatar
LEVA
yeah thanks for the great lesson
Old Nov 29, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I recommend B+Gs to anyone.. handle like a dream well after the initial noises end anyway
Old Nov 29, 2002
i think another thing he was wondering about was what's the difference in quality between say the Ground Controls coil-overs and the Craptive ones? He asked me yesterday and i said that the GC's use Eibach springs which are most definatly of higher quality than the ractive springs. I said that it means they'll be better over time (lifetime warrenty) and they won't sag. can you add anything?
Old Nov 29, 2002
CarbonFly's Avatar
I agree...Ground Controls are a very good coilover to get. At this point, anything is better that Ractive. I don't like any of Ractive's parts, they just seem to be cheaply made.
Old Nov 29, 2002
profurious's Avatar
I Am The Chosen One
profurious is an unknown quantity at this point
tein kit will run you $2300 cdn, i just checked it out the other day
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
EM_WON
Jul 22, 2015 06:49 PM
